Re: NOS vs Blower vs Turbo
[Re: MaxHeadroom]
#1405154
03/20/13 10:28 AM
03/20/13 10:28 AM
Posts: 52,972 Romeo MI
MR_P_BODY
I worked on a project at Chrysler that used a belt driven blower on a 4 banger that when you pressed far enough on the gas pedal it engaged a a/c style clutch on the blower to engage it... that way you werent spinning the blower all the time but yet had the power of the blower... was a fun project
[Re: pittsburghracer]
#1405155
03/20/13 10:31 AM
03/20/13 10:31 AM
Posts: 145 North East
MaxHeadroom
North East
I kinda like NA but then again I always did like doing it the hard way.
Basically my philosophy in the past, engines sounded as good as they ran, though not very steetable if they put out several hundred HP.
[Re: MR_P_BODY]
#1405156
03/20/13 10:35 AM
03/20/13 10:35 AM
Posts: 24,562 Brookeville, Md
Mr.Yuck
Brookeville, Md
you mean it doesn't work like this??? http://www.youtube.com/watch?v=HxhwiAASMH8
[Re: Mr.Yuck]
#1405157
03/20/13 10:53 AM
03/20/13 10:53 AM
MR_P_BODY
Basically it did work like that but we had a micro switch in the gas pedal to engage it... as you rolled into the pedal it would engage the blower and disengage the A/C so you had all the power you could have... it never made it into production... but there were a few projects that I worked on that never made it into production... some did
[Re: Clanton]
#1405160
03/20/13 02:00 PM
03/20/13 02:00 PM
Posts: 4,953 Houston, Texas
TheOtherDodge
Houston, Texas
Mr P, that is the way the blower works on my Mercedes from the factory! Turbo get's my vote. You can adjust the low speed hit with a turbo pretty easily just by changing the exh side of the turbo and moving the rpm band up/down. And in a street car, you don't want to spin! On my turbo truck boost comes in at around 1800 rpms and you can't get on it unless you are going around 60 mph or you will just go up in smoke. At 60 mph in 2nd gear, I can still leave 60 ft of black lines and this is with 315/60 drag radials! My next move is to go with a bigger exh AR to move the power band up even further in hopes of not leaving the line with so much power as to not spin and to help with 60fts. It is also much easier to turn a knob to get more boost than change pulleys. Finally, don't have to mess with belts/slip, etc.
[Re: Cab_Burge]
#1405164
03/20/13 03:08 PM
03/20/13 03:08 PM
Mr.Yuck
Brookeville, Md
me too.....
Me three. I am an all motor guy myself but this day & age if you want to keep up with the jones' you need to spray & boost it.
Me four, I don't want to keep up with the Jones, I want to run thier butts off N/A on pump gas
I used to think that way... boost is like having your cake, eating it and not getting fat.
[Re: Thumperdart]
#1405166
03/20/13 03:41 PM
03/20/13 03:41 PM
Posts: 27,421 Balt. Md
383man
Balt. Md
me too.....
Me 5, can barely make my n/a heap perform.........
Count me as # 6 as I prefer NA also. Ron
