Re: How safe is NOS?
[Re: Quicksilver440]
#1405117
03/20/13 10:26 AM
03/20/13 10:26 AM
Posts: 145 North East
MaxHeadroom
North East
They also need a blow off tube vented out of the passenger compartment.....
OK, that seems like a good precaution, makes it safer, that stuff is nasty. Thanks.
#1405118
03/20/13 10:56 AM
03/20/13 10:56 AM
Posts: 24,562 Brookeville, Md
Mr.Yuck
Brookeville, Md
so the idea I have about mounting mine under the dash is not a good one? I have no heat/ac box or glove box soooo I was going to mount it up under there... sneaky like.
[Re: 1967dartgt]
#1405121
03/20/13 12:24 PM
03/20/13 12:24 PM
Mr.Yuck
Brookeville, Md
where are you going to hide two plates and soleniods? or just not open your hood.
the base plate will hide most if not all of that. I'm also going to cover the gas/NO2 lines w/ rubber hose. The soleniods will be back almost under the intake mounted on the back rail.
[Re: Mr.Yuck]
#1405124
03/20/13 01:46 PM
03/20/13 01:46 PM
Posts: 10,766 Central Valley, CA.
Quicksilver440
Central Valley, CA.
You still could...just vent it out of a hole in the firewall. And the vent is just required for track tech....it's very, very unlikely to blow off while your driving or racing. It's more likely to happen when your car is parked and sitting in a 120 degree garage or out in the sun in the summer (depending on where you live).
just my ....
[Re: MaxHeadroom]
#1405126
03/20/13 02:13 PM
03/20/13 02:13 PM
Posts: 20,660 in a cattle trailer down by th...
Guitar Jones
I've heard it's very addictive. That's why I just say no to N2O.
[Re: Mr.Yuck]
#1405128
03/20/13 09:44 PM
03/20/13 09:44 PM
Posts: 889 Oh
parksr5
Oh
A friend of mine had a 93 Mustang back in the day and he drilled and tapped the bottom of his intake runners and plumbed the nozzle into the bottom of the intake ports. There was a divider at the middle point of the intake on the bottom that hung down and hid everything from sight if you were looking at the engine from the front, the side of the intake was so close to the valve cover that it was hidden from the side and you could not lean over far enough to see it from the back. He ran all of the lines through the trans tunnel and hid the bottle in a subwoofer box in the hatch. He made some good money street racing.
