Dana 60 8 lug to a 5x5.5 #1404968
03/19/13 09:44 PM
03/19/13 09:44 PM
US
BBD150 Offline OP
BBD150  Offline OP
US
Im picking up a dana 60 rear end out of a motor home for a pretty decent price. ive been told by multiple people that it would be a good rear end to cut down and put axles in it for a car.
ive got an 90 d150 that is a v6 that i plan on putting a big block drive train in and the dana 60 would be a better rear end then is in it now. ive been doing research as to what i need to get to convert it,but all ive found is doing the conversions for front dana 60s. im sure its not as simple as getting 5 lug dana 60 axles for it.
any insights?
Re: Dana 60 8 lug to a 5x5.5 [Re: BBD150] #1404969
03/19/13 10:40 PM
03/19/13 10:40 PM
Iowa
76dodgeboy Offline
76dodgeboy  Offline
Iowa
From what I've seen you cut the ends off get the end price that needs welded on like the cars and get axles. Contact Dr Diff. He'll have what you need.
Re: Dana 60 8 lug to a 5x5.5 [Re: 76dodgeboy] #1404970
03/19/13 10:54 PM
03/19/13 10:54 PM
Iowa
76dodgeboy Offline
76dodgeboy  Offline
Iowa
Do a Google search for making a truck Dana 60 into a car Dana 60.
Same thing you want to do just diff bolt pattern witch you should decide what wheels you plan before ordering axles as there isn't alt out there for 5.5". Alt of guys go to 4.5" for a beter variety.
Re: Dana 60 8 lug to a 5x5.5 [Re: 76dodgeboy] #1404971
03/19/13 10:57 PM
03/19/13 10:57 PM
Iowa
76dodgeboy Offline
76dodgeboy  Offline
Iowa
Summit racing type in "Dana 60 axle end" in the search box
Re: Dana 60 8 lug to a 5x5.5 [Re: BBD150] #1404972
03/19/13 11:55 PM
03/19/13 11:55 PM
Chilliwack B.C. Canada
RUNCHARGER Offline
RUNCHARGER  Offline
If you're not in a rush and have old trucks in junkyards near you, there were Dana 60's installed in 60's F100's with the 5 on 5.5 pattern. I narrowed one of those for my 64 a few years ago, but it would be near a bolt in for your app.
Sheldon
Re: Dana 60 8 lug to a 5x5.5 [Re: RUNCHARGER] #1404973
03/20/13 01:34 AM
03/20/13 01:34 AM
Granite Bay CA
Kern Dog Offline
Striving for excellence
Kern Dog  Offline
Granite Bay CA
Be aware that some motorhome Dana axles look like a 60 but are actually a 70 series. I thought that those had a larger ring gear and almost nothing swaps over.
Re: Dana 60 8 lug to a 5x5.5 [Re: Kern Dog] #1404974
03/20/13 01:26 PM
03/20/13 01:26 PM
dogdays Offline
dogdays  Offline
But the drag race boys are starting to use the 70 gears in their 60 rears.
R.
Re: Dana 60 8 lug to a 5x5.5 [Re: RUNCHARGER] #1404975
03/20/13 10:31 PM
03/20/13 10:31 PM
US
BBD150 Offline OP
BBD150  Offline OP
US
Sheldon
ive been looking for dana 60 5 lug factory axles. i read that they were put in ram chargers in the early 90s in one of the special packages. were they ever put in the 94 and later trucks?
i also read that its usually cheaper to have a machine shop do the work changing the lug on the 60. is there any companies in the Indiana Ohio or Kentucky area that are good?
Re: Dana 60 8 lug to a 5x5.5 [Re: BBD150] #1404976
03/20/13 11:28 PM
03/20/13 11:28 PM
State of Confusion
hp383 Offline
Just a normal tag again
hp383  Offline
State of Confusion
Measure the width of the axle. Being a dual rear, it may require some tubbing of the fenders to fit.
They will often be narrower than a standard truck dual rear, like a cab & chassis truck
Join the Penguin Liberation Front!!
Stop the Hippo Occupation!
Re: Dana 60 8 lug to a 5x5.5 [Re: BBD150] #1404977
03/21/13 12:03 AM
03/21/13 12:03 AM
N
NITROUSN Offline
NITROUSN  Offline
N
Wrong on both. No 60 rear 5 lug.
Re: Dana 60 8 lug to a 5x5.5 [Re: NITROUSN] #1404978
03/21/13 12:41 AM
03/21/13 12:41 AM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
Not quite true.
Dodge did put 5 lug 5.5 pattern D 60s in Ramchargers that were built and sold
in Mexico. The chance of finding 1 very far north of the border is highly unlikely..
I am truckless..
Re: Dana 60 8 lug to a 5x5.5 [Re: 340SHORTY] #1404979
03/21/13 02:50 AM
03/21/13 02:50 AM
State of Confusion
hp383 Offline
hp383  Offline
State of Confusion
How about the 5 lug 3/4 ton Dodge vans? Would those have the D60 or were they using a 9-1/4"
Re: Dana 60 8 lug to a 5x5.5 [Re: hp383] #1404980
03/21/13 03:16 AM
03/21/13 03:16 AM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
The 80s B250 my friend had was a 9 1/4.
I am truckless..
Re: Dana 60 8 lug to a 5x5.5 [Re: 340SHORTY] #1404981
03/21/13 09:49 AM
03/21/13 09:49 AM
Des Moines IA
Soopernaut Offline
Soopernaut  Offline
Des Moines IA
International used a 5 on 5.5 bolt pattern Dana 60 on some trucks and Travelalls.
1970 Dodge d100/eventually going on a 77 D100 frame
Re: Dana 60 8 lug to a 5x5.5 [Re: Soopernaut] #1404982
03/21/13 12:53 PM
03/21/13 12:53 PM
dogdays Offline
dogdays  Offline
Yeah, good luck finding one of THOSE.....
R.
Re: Dana 60 8 lug to a 5x5.5 [Re: hp383] #1404983
03/21/13 08:19 PM
03/21/13 08:19 PM
US
BBD150 Offline OP
BBD150  Offline OP
US
yea i plan on tubbing the bed anyway to fit some wider tires so thats not really an issue.
im trying to decide if i want to convert the d60 or just stick with 8 1/4 or 9 1/4 rear ends.
Re: Dana 60 8 lug to a 5x5.5 [Re: BBD150] #1404984
03/21/13 08:21 PM
03/21/13 08:21 PM
RUNCHARGER Offline
RUNCHARGER  Offline
If you have to spend any money on the small rearends at all, then it's time to go Dana 60, it's money well spent in the end.
Sheldon
Re: Dana 60 8 lug to a 5x5.5 [Re: RUNCHARGER] #1404985
03/21/13 10:18 PM
03/21/13 10:18 PM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
Id personally never put a dime into an 8 1/4 or 9 1/4 for performance purposes.
I am truckless..
Re: Dana 60 8 lug to a 5x5.5 [Re: 340SHORTY] #1404986
03/21/13 11:38 PM
03/21/13 11:38 PM
N
NITROUSN Offline
NITROUSN  Offline
N
News to me. Can you back the statement up?
Re: Dana 60 8 lug to a 5x5.5 [Re: NITROUSN] #1404987
03/22/13 01:10 AM
03/22/13 01:10 AM
lakeside ca
1moparman Offline
1moparman  Offline
lakeside ca
mexico likes to use what it makes and since dana/spicer are there thats what they use I've seen all kinds of dana axles in mexican trucks and vans...... I can also confirm the internantional 5 on 5 1/2 I have one out of a travelall I pulled from the wrecking yard
Get Real Get Mopar
