Valves opening while tightening rocker arms? 318 magnum
#1404446
03/18/13 03:32 PM
03/18/13 03:32 PM
Posts: 1,630 North Central Florida
eightlitermopar
I have a question about putting this motor together regarding the pushrods and valves opening. This is also posted on my original magnum headed 318 post here https://board.moparts.org/ubbthreads/show...e=0#Post7077141Ok, so I finally measured very carefully and I am installing pushrods today. I ended up using a thin head gasket, so my “zero lash” length for my pushrods was 7.543. According to Comps website, I could calculate .020 - .070 preload with my hydraulic lifters. (The lifters and pushrods are both Comp) I ended up going with an even number at 7.600 for pushrod length. However, when I tighten down the rocker arms, I can see the valve opening. This happens on the valves that are supposed to be closed (the cam lobe is on the “closed” side) These cam and lifters are used previously (together) and so I am wondering if I just need the lifters to “bleed down” ? What am I missing here? I hate to button this up and have problems when I first fire it up. Please help Eightlitermopar
Mopar or no car
Re: Valves opening while tightening rocker arms? 318 magnum
[Re: eightlitermopar]
#1404447
03/18/13 03:47 PM
03/18/13 03:47 PM
eightlitermopar
I should also add...
I let the motor sit for 30-45 minutes (in case the lifters did need to "bleed down").
I turned the motor slowly over with a breaker bar and no pistons were contacting any valves for the full 720 degrees...
eightliter
Mopar or no car
[Re: JohnRR]
#1404451
03/18/13 05:38 PM
03/18/13 05:38 PM
eightlitermopar
Hmm….I’ll have to do some more research on this… This is a LA 318 motor with the later style magnum heads. These are not stock 1969 heads. The mopar performance pushrods designed to work with the magnum headed, LA small blocks was 7.625 inches long. This was part number P5007477 and has been discontinued. Some have even run 7.650 inches on their engine combos. The common complaint I see is that the pushrods for this conversion might have been too SHORT. If anything, the pushrods I have now would be even shorter…..which would give me no preload at all. This info was gathered based on information I got offline http://www.dippy.org/forum2/index.php?topic=295.0and http://www.moparmusclemagazine.com/techarticles/mopp_0409_318_engine_build/viewall.htmljust to name a few…. This really has me confused… Eightlitermopar
Mopar or no car
[Re: RapidRobert]
#1404454
03/19/13 10:14 AM
03/19/13 10:14 AM
Posts: 75,125 A Banana Republic near you.
JohnRR
They will bleed down. Take a look at it in the morning.
yeah see what your preload is in the morning on the base circle
What happens when the engine is started up and the lifters are filled with pressurized oil ??
How much have the heads been cut vs. stock ?
#1404456
03/19/13 11:42 AM
03/19/13 11:42 AM
Posts: 5,746 Ontario, Canada
Dodgem
Ontario, Canada
I have to check more.
Thought the rockers where adjustable like a chev but says they are not!
Oh well
[Re: Dodgem]
#1404457
03/19/13 11:47 AM
03/19/13 11:47 AM
Posts: 16,123 Grand Haven, MI
patrick
Grand Haven, MI
what rockers are you using again? stock magnum pedestal mount?
#1404459
03/19/13 12:16 PM
03/19/13 12:16 PM
Dodgem
Ontario, Canada
What cam shaft?? does the roller hydraulic not use a much shorter pushrod?? ![](/ubbthreads/images/graemlins/1343795-scratchchin.gif) Well reading your other post sounds like you stayed with your original LA cam and lifters so it should not be a problem. did you measure the comp pushrod lenghs to see you got the correct ones? maybe you are not on the back of the cam??? ![](/ubbthreads/images/graemlins/shruggy.gif)
#1404460
03/19/13 03:01 PM
03/19/13 03:01 PM
JohnRR
Eightlitermopar
according to a post in that thread you link at least one person says he is using 7.625 pushrods so if that is the case then you are fine BUT he doesn't say what he has done to the heads or block , decking , what cam he has , stock or reground , flat tappet or roller , and what head gasket .
when you determined the length were you 1000000% sure the lifter was on the absolute base of the CAM LOBE ? The base is 180* from the nose of the lobe , anywhere else and you are starting to get lift. also note that AMC lifters are not the same as Mopar lifter in the location of the pushrod seat.
I personally think your pushrods are too long, you should have went fro the .020 extra length instead of closer to .060.
You need to reconfirm your measurements.
