Re: name of the company remaking the early volt refulators [Re: Snoopy] #140413
10/24/08 09:50 PM
10/24/08 09:50 PM
Indiana
maxie Offline OP
maxie  Offline OP
Indiana
Ground one of the field connectors. The arrow shows you which one to ground.
I have the other one grounded on mine. no problems here.
Re: name of the company remaking the early volt refulators [Re: maxie] #140414
10/25/08 07:25 AM
10/25/08 07:25 AM
Maryland USA
beatgoeson Offline
beatgoeson  Offline
Maryland USA
Does anybody re-stamp the covers? I have one I cleaned and painted and would like to have stamped. Would like to have my pertronics coil stamped too.
Re: name of the company remaking the early volt refulators [Re: beatgoeson] #140415
10/25/08 12:28 PM
10/25/08 12:28 PM
IL, Aurora
ademon Offline
ademon  Offline
IL, Aurora
I think someone does, one of the companys that sells decal/stripe sets. not sure which one
Re: name of the company remaking the early volt refulators [Re: ademon] #140416
10/25/08 01:01 PM
10/25/08 01:01 PM
Mass
Mike Mancini Offline
Mass
www.instrument-specialties.com does, not on the web page, but they do.
Mike
Michael L. Mancini
American Muscle Car Restorations, Inc.
65 Foliage Drive
N. Kingstown, RI
Premium Quality Restoration Services for Hi-Performance & Classic Automobiles. OE Specialists.
Instrument Specialties, Inc
www.manciniresto.com
www.performancecargraphics.com
Re: name of the company remaking the early volt regulators [Re: maxie] #140417
11/05/08 08:30 PM
11/05/08 08:30 PM
Seattle WA
RichV Offline
RichV  Offline
Seattle WA
Be carefull of these, I had one short out to the case and melt the wire to the ignition side. Fortunately turning off the key cut off the power. The terminal shifted in the body and since the pass through for this lug was not isolated it grounded the wire to the case. I was able to cut the wire out of the harness and splice in a new one. The configuration is slightly different than the one shown. FBO assured me that his would not have the problem I had. The new regulator he sold me was exactly the same as the one that failed. This type regulator has a bare wire going from the circuit board to the ignition lug.
Re: name of the company remaking the early volt regulators [Re: RichV] #140418
11/06/08 08:24 AM
11/06/08 08:24 AM
Massachusetts
LYNCHROAD69.5 Offline
Massachusetts
It appears the same thing happend to my car with the previous owner...he ended up grounding the alternator and all seems fine (1970 alternator). The reason I know is I just noticed the wire from IGN side is melted from the firewall bulkhead back to the ignition switch in the dash.
I dont want this to happen again with new motor so I need to ask...if I have petronix (electrical ingnition) in my car with correct alternator (remand with one field) what style voltage regulator can I use (old style..NOS, or new one specificaly for cars with electronic ignition)?
Re: name of the company remaking the early volt regulators [Re: LYNCHROAD69.5] #140419
11/06/08 11:25 PM
11/06/08 11:25 PM
Massachusetts
Massachusetts
