Re: What happened to the small block Super Victor Head?
[Re: J_BODY]
#1404100
03/18/13 11:46 AM
03/18/13 11:46 AM
Posts: 9,892 Weddington, N.C.
Streetwize
Weddington, N.C.
The Edelbrock heads' concept seemed to me to be "a little bit of everything...but not enough of anything" EX: 2.15" intake valves = GOOD for new motors but there goes the 'bolt-on swap' aspect. There needed to be something like at least a 2.05" or 2.08" standard option so people don't have to re-cut their pistons. Offset W2 style rockers, probably would require offset lifters for a typical 59 degree roller and if it's a Hydraulic roller (like for a street/strip 416) do they even make an offset HR lifter? not full race but for a big cube moderate RPM dual purpose motor HR's are light years ahead of where they were 10-15 yrs ago. Not sure what they would flow but... Always seemed to me MP or someone should just recast a high quality W5 (W2 aluminum) or W8 casting with all of the corrections that would accept the present CNC programs and readily available manifolds. Why not make it easy
[Re: rck850]
#1404103
03/18/13 08:54 PM
03/18/13 08:54 PM
Posts: 982 western pennsylvania
b1dartsport
The biggest question was just raised by streetwise. Why is the W5 not being made again? With all the new stroker cranks,new blocks and all the stuff available right now it just seems like Mopar is laying an egg on this. Edelbrock should have just bought the W5 templates and just recast the head instead of designing something new.
The W5 was always considered to be an excellent head, port and design wise. What was always in question was poor castings and terrible metalurgy. If Edelbrock just copied them I'm sure the quality would be much better.
[Re: pittsburghracer]
#1404105
03/18/13 09:49 PM
03/18/13 09:49 PM
Posts: 1,044 Victoria, Australia
Ian
Victoria, Australia
Shhhhh the Chinese may be listening and copy it like the ones Dr. J is selling that were copied off Edelbrock. I know you guys would never stoop as low as running that copied imported stuff.
the in ching chong head can not be any crapper than some of the sb indy i have seen
#1404106
03/18/13 10:03 PM
03/18/13 10:03 PM
Posts: 20,203 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Now on the serious side I was checking out some of the Trick Flow heads at the display during Last years Halloween Classic@ Norwalk Oh. One of the guys came over to talk and I asked him if they offered anything for Mopars. He said no and then asked me my thoughts on what area needed attention. As soon as I said we needed a head for a stock type Mopar small block that was capable of 300-330 cfm out of the box. As soon as I said that he called over 3 other guys working the booth. We all talked for almost an hour as the first guy had suggested to them the same thing. From what I understand Trick Flow is a spin-off of Summit Racing and is located right down the road from their Ohio store. The weather turned to crap after our talk and I didn't make it up to the display again but I would love to have a further discussion. They seemed very open to discussion on this idea.
#1404107
03/18/13 10:55 PM
03/18/13 10:55 PM
Posts: 35 Minot, ND
darndart
Minot, ND
That would be awsome! I run several versions of their Twisted Wedge Ford heads, and they work outstanding!
73 Dart Sport 340, 410ci, Indy 360-2 230CNC. 72 Demon 340 4-speed 01 Ram Quad Cab 89 Mustang LX Boss 331,C4,HP76mm turbo, FAST EFI 86 Mustang GT 5.0 AOD 82 Capri RS 306, Fox Lake Stage 1 TW, N41, T5,etc.
[Re: Chris'sBarracuda]
#1404112
03/19/13 02:55 AM
03/19/13 02:55 AM
Posts: 1,025 Las Vegas, NV
dodgeboy11
Las Vegas, NV
I gave up and bought some 59 deg W9's. Guides and seats installed, cnc'd chambers and into the bowls very lightly. Not impressed with 3/8" valve guides though. I mean, c'mon guys, you put 5/16" stems in the hemi and then stick 3/8" in everything else?? Regardless, those guides are coming out and 5/16" is going in. The valve job, while finished (won't be when I change guides), is on the small side. Calls for 2.150 intake valve, but the valve seat contact OD is 2.120, so I think some 2.125" valves will fit the bill nicely to help with the shrouding. I already know the chambers clear the 4.030" bore. I can actually open the chambers up every so slightly to also ease the shrouding. Will be interesting to see if the 18 deg valve pockets will work with these 15 deg heads or if I'll need to cut the pistons. I suspect the latter as the valve pocket looks barely big enough to clear 2.080" intake valve. I suspect I'll be learning a lot with this setup before it's running. Thankfully the crank isn't balanced yet so if I need to change pistons, that won't be an issue. As for the Trick Flow deal, that would be great. Hopefully the economy DOES turn back around.
[Re: dodgeboy11]
#1404113
03/19/13 03:00 PM
03/19/13 03:00 PM
Posts: 5,486 SoCal
Brian Hafliger
SoCal
All I can say is the BB head will be first and then the SB head. Not my choice! But it's what will happen. I've talked with 2 engineers there and provided detailed info including measurments on things they needed so I'm pretty sure they were'nt foolin' me It won't be anytime soon though unfortunately...
Brian Hafliger
[Re: WO23Coronet]
#1404115
03/19/13 03:56 PM
03/19/13 03:56 PM
Posts: 12,424 Kalispell Mt.
HotRodDave
Kalispell Mt.
Don't know how they are gonna twist the valves and keep them on shafts seems a magnum head would be easiest and make the most sense any how.
