440-1 head push rod oiling vs through head oiling #1403955
03/17/13 08:58 PM
03/17/13 08:58 PM
wentzville mo
1974PW Offline OP
1974PW  Offline OP
wentzville mo
i have the big easy head with t&d rockers im set up to do push rod oiling but my question is, is just push rod oiling enough by its self or should i run a restricted line off the block to my head to oil the shafts. originaly i was going to just do the line off the block to the head but was worryed about the push rod ends so i went with push rod oiling to cover that. but now im wondering how good the push rod oiling feeds the shaft.
Re: 440-1 head push rod oiling vs through head oiling [Re: 1974PW] #1403956
03/17/13 09:18 PM
03/17/13 09:18 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
My -1 are push rod oiled with T&D individual shaft rockers. Comp 892 tappets with bushed lifter bore,.060" orifice. More than enough oil. I may restrict it in the future.
Doug
Re: 440-1 head push rod oiling vs through head oiling [Re: 1974PW] #1403957
03/17/13 10:57 PM
03/17/13 10:57 PM
Virginia Beach, VA
O
Old School Offline
Old School  Offline
O
Virginia Beach, VA
if you are using the solid shaft t&d set-up, i would use the rear of the block fittings for oiling. it is much simpler and more than enough. i even restrict the oil to the heads with this set-up. the t&d,s are unique in that with this type set-up, the pushrod and rocker cup are pressurized with oil.
68 cuda formula S 588" bb 5sp
70 CUDA CONVERT 500" 5SP (SUBLIME)
70 CUDA CONVERT 500" 5SP (PLUMCRAZY):TOO MUCH HORSEPOWER, IS ALMOST ENOUGH!
Re: 440-1 head push rod oiling vs through head oiling [Re: Old School] #1403958
03/17/13 11:01 PM
03/17/13 11:01 PM
wentzville mo
1974PW Offline OP
1974PW  Offline OP
wentzville mo
since im already set up for push rod oiling it should work the opposite way shouldnt it? oil the cups first then the shaft?
