Dropped The Tank 93 Cummins #1403283
03/16/13 05:31 PM
03/16/13 05:31 PM
Not2farfromNashville, TN
Rug_Trucker Offline OP
Fuel was not going to the lift pump. I found a seal from a fuel treatment bottle that may have plugged it up.
I have 2 fittings on the top that have no hoses going to them. 1 is a big line that come straight out by the return and supply lines.
The other is a small one at a 90* angle on top of a large round raised thingy.
Where do these lines go? Are they necessary?
"The only thing to do for triumph of evil is for good men to do nothing"
"NUNQUAM NON PARATUS!"
Re: Dropped The Tank 93 Cummins [Re: Rug_Trucker] #1403284
03/16/13 08:35 PM
03/16/13 08:35 PM
Maine
jerseybud Offline
jerseybud  Offline
Maine
The 90* fitting should be about 3/16 size and that would be a vent.
As I recall, the other fitting is blind and goes no where.
Sounds normal, but I'm just guessing w/o pics
Re: Dropped The Tank 93 Cummins [Re: jerseybud] #1403285
03/17/13 10:08 AM
03/17/13 10:08 AM
Good memory! The straight isn't open. It's a gasser thing? The other is a rollover vent.
