Re: LCA repair
[Re: 74_360_Cuda]
#1403052
03/16/13 12:53 AM
03/16/13 12:53 AM
Posts: 18,678 Fresno, CA
Jim_Lusk
Fresno, CA
The other end of the LCA is held together by large rivets. I think if I had a problem like you are describing I would cut back the lips (if those arms have the lips - check out my video at http://www.youtube.com/watch?v=Nwes-SP8u4w at the 2:28 mark for arms without the lip). Then I would source a steel ring the right diameter (even if I had to make one) and weld it in place to the arm.
Re: LCA repair
[Re: Jim_Lusk]
#1403053
03/16/13 01:52 AM
03/16/13 01:52 AM
Posts: 27,471 So Cal
autoxcuda
So Cal
Jim, what do you think about swagging the stamped lip-hole to decrease the ID. Probably need to heat them. In just in 3-4 points spaced roughly equally around the circumference.
You could weld a ring or support to hold it tight. Or would welding just warp up what you swagged over.
Re: LCA repair
[Re: Jim_Lusk]
#1403055
03/16/13 10:51 AM
03/16/13 10:51 AM
Posts: 387 Montreal PQ, Canada
74_360_Cuda
Montreal PQ, Canada
They are the cheaper version without the lip (74 Cuda), I was also suspecting that this is why they have more wear than most peoiple have. I think most of the play is on the FWD side so the T bar recetpacle is not in the way to weld a ring. I will give it a try, thanks! BTW I had already seen your video, thanks for posting valuable info like that! Here is a short video showing the paly I have: https://www.youtube.com/watch?v=6GDpjICbi1AObviously I have a combination of radial & axial play so I will also do your fix.
Re: LCA repair
[Re: BergmanAutoCraft]
#1403058
03/16/13 10:04 PM
03/16/13 10:04 PM
Jim_Lusk
Fresno, CA
Sounds like I need to design a bearing for these...
Do I get any royalties for the idea?????
There really shouldn't be a problem putting one on either side as the lever is in the middle.
Re: LCA repair
[Re: 74_360_Cuda]
#1403059
03/16/13 10:25 PM
03/16/13 10:25 PM
Posts: 4,323 NY NY
340duster340
NY NY
why not just replace the lca. it's 40 years old and worn out.
1966 Dart GT
...down to only 1 mopar for the first time in 15 years!
Re: LCA repair
[Re: 340duster340]
#1403060
03/16/13 10:41 PM
03/16/13 10:41 PM
Jim_Lusk
Fresno, CA
And the replacement is also 40 years old and needs some attention, too. I also love fixing stuff. I picked up a tweaked A-body k-member so that I could fix it. That job is almost done, but is on hold for a while.
Re: LCA repair
#1403062
03/17/13 02:20 AM
03/17/13 02:20 AM
autoxcuda
So Cal
Those two surfaces only rotate relative to each other when you adjust the ride height of the car. I think they were not a extremely tight fit to begin with and just 40 years of vibration and road impacts cause wear.
Now you could put a bearing to replace the LCA bushing. You'd run a big spherical bearing in there. But I don't think that would be a good idea for a street car. Most of the load of the front suspention goes through that location. I just don't think they would wear well with street driving and roads. Great for race tracks which are smooth.
It could only be a plain bearing if the absolute center axis of the LCA pivot pin perfectly intersected the center axis of the strut rod to k-member spherical joint. Otherwise there were be binding.
Re: LCA repair
[Re: Jim_Lusk]
#1403064
03/17/13 03:15 AM
03/17/13 03:15 AM
autoxcuda
So Cal
If it were me I would just put a plain steel bushing together that could be welded to the outside of the LCA, front and rear.
Like a ring with an ID that was very tight with the OD of the pivot adjuster that goes through the LCA?
Re: LCA repair
[Re: autoxcuda]
#1403065
03/17/13 03:18 AM
03/17/13 03:18 AM
Jim_Lusk
Fresno, CA
Yup. The rear could be fairly long, too. But, if it were long I might think about having it greasable.
Re: LCA repair
[Re: Jim_Lusk]
#1403066
03/17/13 03:30 AM
03/17/13 03:30 AM
autoxcuda
So Cal
I think this is something that wears little by little over a long period of time. And they might not have been that accurate/tight when brand new. I don't know, I don't have an NOS lower control arm.
Re: LCA repair
[Re: autoxcuda]
#1403067
03/17/13 08:31 AM
03/17/13 08:31 AM
Posts: 3,577 Long Island, NY USA
BergmanAutoCraft
Long Island, NY USA
Not sure what your talking about here. We're talking about the t bar socket assembly not the lca. I'm already making a Delrin lca bushing. I'd take the arms apart and machine something for the inside and reassemble.
Re: LCA repair
#1403068
03/17/13 03:18 PM
03/17/13 03:18 PM
Posts: 4,302 Nebraska
72Swinger
Nebraska
He's saying the only time that bearing would rotate is when you adjust the torsion bars really. The suspension movement up and down , the bearing would remain static through the whole travel.
Mopar to the bone!!!
Re: LCA repair
[Re: autoxcuda]
#1403069
03/17/13 08:32 PM
03/17/13 08:32 PM
74_360_Cuda
Montreal PQ, Canada
Making a ring with a precise fit might be difficult to acheive. I was thinking you get a close match and you cut the ring in 4 and weld them individualy. As mentionned there is no rotation going on when the suspension is moving, this is just to transfer the load without discplacement.
