Page 2 of 3 1 2 3
Re: External Oiling System Question [Re: Big Wedge] #1403027
03/16/13 09:44 PM
03/16/13 09:44 PM
Manitoba, Canada
Big Wedge Offline
Big Wedge  Offline
Manitoba, Canada
The next series of 3 pictures is of the baffle I adding into the rear of the sump. I wanted to make sure the oil stayed in the sump area during launch at the track. It doesn’t have to be completely tight and welded all around as long as you are providing some oil control. Again, I have never experienced 0 oil pressure at the race track with this arrangement.
Re: External Oiling System Question [Re: Big Wedge] #1403028
03/16/13 09:45 PM
03/16/13 09:45 PM
Manitoba, Canada
Big Wedge Offline
Big Wedge  Offline
Manitoba, Canada
2nd
Re: External Oiling System Question [Re: Big Wedge] #1403029
03/16/13 09:47 PM
03/16/13 09:47 PM
Manitoba, Canada
Big Wedge Offline
Big Wedge  Offline
Manitoba, Canada
… and 3rd. As you can see, I also placed the pickup at the rear of the sump. This aids in picking up oil on launch. I hope this helps.
Garth
Re: External Oiling System Question [Re: Big Wedge] #1403030
03/16/13 09:54 PM
03/16/13 09:54 PM
Manitoba, Canada
Big Wedge Offline
Big Wedge  Offline
Manitoba, Canada
Bill,
I found another picture of Rick's oil line.
Garth
Re: External Oiling System Question [Re: Big Wedge] #1403031
03/17/13 12:35 AM
03/17/13 12:35 AM
Indiana
Gabby63 Online content
Gabby63  Online Content
Indiana
Hey guys , I don't want to hijack the post but can you purchase the sump in the pan and oil line and the Milodon pump cover as a kit ? If so where ? I have been wanting to have the external set up like this but never pursued it . Gary
Re: External Oiling System Question [Re: Gabby63] #1403032
03/17/13 01:58 AM
03/17/13 01:58 AM
MB,CAN
PC-CHARGER Offline
PC-CHARGER  Offline
MB,CAN
I believe it is still available as a kit although it uses the old style pump cover that has the gasket issue that Garth mentioned. Here's a link to the kit at Summit.
http://www.summitracing.com/parts/mil-21010/overview/year/1970/make/dodge/model/charger
The new style cover Milodon offers is a one piece unit that does not have the gasket problem but it does not come with the pickup, lines and fittings. Here's a link to that cover.
http://www.summitracing.com/parts/mil-21215/overview/year/1970/make/dodge/model/charger
There are others who make the one piece pump cover as well and Milodon sells their pickup seperately as well here:
http://www.summitracing.com/parts/mil-21300/overview/make/dodge
The lines and fittings are all standard -10 AN braided line available most anywhere.
Re: External Oiling System Question [Re: Gabby63] #1403033
03/17/13 01:45 PM
03/17/13 01:45 PM
Colorado Springs, Colorado
cool70cuda Offline OP
Gary,
The #21010 system kit now comes with the new one piece pump cover. I got mine from Jegs and they said they don't have any of the older 2 piece covers left.
Bill
Re: External Oiling System Question [Re: Big Wedge] #1403034
03/17/13 02:10 PM
03/17/13 02:10 PM
Garth & Rick, that is some great documentation! I thought I was the only one who took a bunch of step by step photos of everything seeing the pics make it much easier to understand
Garth, the modified fitting coming out of the pump cover would be my biggest problem...That is some awesome skill cutting and welding up that fitting I don't have that skill and not sure any of my friends do either.
Rick, the tubing you used, is it welded or soldered?
Also, question for all: Are you using the "O" ring at the connection/fitting at the pan or a gasket of some sort...or both?
Re: External Oiling System Question [Re: Gabby63] #1403035
03/17/13 02:17 PM
03/17/13 02:17 PM
Gary, This is what came in the kit plus the pick up/sump for the pan. The pump was extra.
Re: External Oiling System Question [Re: 66er] #1403036
03/17/13 02:29 PM
03/17/13 02:29 PM
66er - Any chance you might be able to take a few pics of your set up?
Re: External Oiling System Question [Re: cool70cuda] #1403037
03/17/13 02:38 PM
03/17/13 02:38 PM
Tucson, Arizona
MRMOPAR Offline
MRMOPAR  Offline
Tucson, Arizona
BigWedge - looks like that block was ventilated in one picture.
68 RR 528" INDY MAXX 07 2500 CTD Southwest International Raceway - IHRA - Tucson, AZ
Re: External Oiling System Question [Re: cool70cuda] #1403038
03/17/13 05:10 PM
03/17/13 05:10 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
Because the pickup and fitting are not pipe thread you need sealant on the threads. You need the o ring between the pickup and pan to prevent seepage. The big washer is just there as support for the thin sheet metal of the pan.
Re: External Oiling System Question [Re: cool70cuda] #1403039
03/17/13 07:43 PM
03/17/13 07:43 PM
Manitoba, Canada
Big Wedge Offline
Big Wedge  Offline
Manitoba, Canada
Bill, the fitting was not too bad to make. I just cut out a V from a 90 and filed it by hand until it lined up with the opening in the cross member. A friend of mine did the TIG welding. Remember, this is under suction, not pressure.
I remember having to fiddle with the pickup. I forget how I did this. Now you understand why I have some many pictures. LOL. My best recollection was I discarded the o-ring. I used an aluminum washer on the outside of the pan. I had a friend thread it to better align it on the fitting but that is not necessary. Then I used silicone on either side of the sump wall to seal.
Garth
Re: External Oiling System Question [Re: MRMOPAR] #1403040
03/17/13 07:52 PM
03/17/13 07:52 PM
Manitoba, Canada
Big Wedge Offline
Big Wedge  Offline
Manitoba, Canada
Yup. That is now my mock up block for myself and Mopar friends.
Garth
Re: External Oiling System Question [Re: cool70cuda] #1403041
03/17/13 10:08 PM
03/17/13 10:08 PM
MB,CAN
PC-CHARGER Offline
PC-CHARGER  Offline
MB,CAN
The tubing is welded. I don't think soldering would hold in this application. It was fabricated from two 90 degree Aeroquip adapters.
As for the fitting in the pan, I used a washer kit from Doty manufacturing that is made specifically for this application. It is a large aluminum washer that is relieved for an "O" ring on the inner circumference.
http://dotymi.com
Garth's method or mine each require some welding although it is minor and any welding shop would likely do it for a minimal charge. I would think that a longer piece of braided steel line could be looped under the oil filter in place of the steel line I used and would eliminate any welding but the line would have to be supported so it doesn't rub somewhere.
Re: External Oiling System Question [Re: PC-CHARGER] #1403042
03/17/13 10:32 PM
03/17/13 10:32 PM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
I use a dual set up,but I recommend using a prefilter also
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: External Oiling System Question [Re: hemi-itis] #1403043
03/17/13 11:44 PM
03/17/13 11:44 PM
Graham, WA
P
Polarapete Offline
Polarapete  Offline
P
Graham, WA
Bump
1986 Dodge Ramcharger 440 2wd, Bracket Racer Under Construction
1998 Ram 2500 QuadCab, new daily driver.
2008 Honda Element
2014 Carry-On 7x14 Cargo Trailer
Re: External Oiling System Question [Re: cool70cuda] #1403044
03/18/13 02:23 PM
03/18/13 02:23 PM
Indiana
Indiana
Thanks for the info , Now I kind of know what to expect & what the history is on those components . Will be getting this soon . Gary
Re: External Oiling System Question [Re: cool70cuda] #1403045
03/18/13 02:56 PM
03/18/13 02:56 PM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
Mine is dual line
crude luck at where it went
now with andy's motor plate
Re: External Oiling System Question [Re: Dodgem] #1403046
03/30/13 01:08 AM
03/30/13 01:08 AM
I finally had a chance to get some things mocked up and after messing with it a bit I think I might go this way with it. Thoughts?
Page 2 of 3 1 2 3
