Re: Driveshaft Length Help With Caltracs [Re: DoctorDiff] #1402909
03/17/13 04:13 PM
03/17/13 04:13 PM
NJ central
Scamp408 Offline OP
Scamp408  Offline OP
NJ central
I am still runnin 7290
Re: Driveshaft Length Help With Caltracs [Re: mopar dave] #1402910
03/17/13 04:14 PM
03/17/13 04:14 PM
Polson, MT
DoctorDiff Offline
DoctorDiff  Offline
Polson, MT
The front U-joint should run as close to the tail housing as possible to avoid a vibration.
Re: Driveshaft Length Help With Caltracs [Re: DoctorDiff] #1402911
03/17/13 05:01 PM
03/17/13 05:01 PM
Shannonville, Ont
Blown 68 R/T Offline
Shannonville, Ont
Could someone post a pic of the slip yoke that's too short/long and one thats right?
Re: Driveshaft Length Help With Caltracs [Re: Blown 68 R/T] #1402912
03/17/13 06:52 PM
03/17/13 06:52 PM
Polson, MT
DoctorDiff Offline
DoctorDiff  Offline
Polson, MT
Unbolt the driveshaft. Ideally, the slip yoke should slide forward 3/4" to 1" before it bottoms out inside the transmission.
Re: Driveshaft Length Help With Caltracs [Re: DoctorDiff] #1402913
03/18/13 09:25 AM
03/18/13 09:25 AM
Mt Morris Michigan
mopar dave Offline
mopar dave  Offline
Mt Morris Michigan
I had 1 1/4" of shaft sticking out the end of the trans housing. if I had 1" of yoke to housing clearance the shaft would be bottomed out in the yoke or pretty close to it.
Re: Driveshaft Length Help With Caltracs [Re: mopar dave] #1402914
03/18/13 03:44 PM
03/18/13 03:44 PM
scratchnfotraction Offline
In this case I would slide yoke in till it bottoms out,now measure from center of cap to center of cap,then subtract 1" from your measurement.
Re: Driveshaft Length Help With Caltracs [Re: scratchnfotraction] #1402915
03/18/13 04:57 PM
03/18/13 04:57 PM
NJ central
Scamp408 Offline OP
Scamp408  Offline OP
NJ central
I measured it all up and I have aprox 1in give or take a little with my DS. I went to where I bought the shaft sometime ago and they say bottom yoke,pull out and inch than measure center to center. The newer yoke will not go in all the way but if I force it I am sure it would. I cant see any twisted splines but something is in there. The way it was I only had 1/2" of slip.
Re: Driveshaft Length Help With Caltracs [Re: Scamp408] #1402916
03/19/13 01:40 AM
03/19/13 01:40 AM
Nor-Cal
loaderpro Offline
loaderpro  Offline
Nor-Cal
It does not matter how far out the shaft is....You need at least 1" of freeplay forward on a leaf spring car and 3/4" on a ladder bar or 4 link car. Take the rear u-joint straps off, measure, then push it forward, remeasure, this also must be done at normal ride height.
Re: Driveshaft Length Help With Caltracs [Re: loaderpro] #1402917
03/22/13 08:27 PM
03/22/13 08:27 PM
NJ central
Scamp408 Offline OP
Scamp408  Offline OP
NJ central
Just got new slip yoke and this one goes in less than the other . Does anybody make good parts anymore . Now what?
Re: Driveshaft Length Help With Caltracs [Re: Scamp408] #1402918
03/23/13 10:58 AM
03/23/13 10:58 AM
Staten Island N.Y.
Dap Offline
Dap  Offline
Staten Island N.Y.
I twisted the spline in my 7290 yoke and replaced it with a MW 1350 yoke along with a new shaft.
PRH446
10.084 @ 135.21 mph N/A through chambered mufflers,3300lbs. Stock stroke wedge
Re: Driveshaft Length Help With Caltracs [Re: Dap] #1402919
03/23/13 11:53 AM
03/23/13 11:53 AM
NJ central
Scamp408 Offline OP
Scamp408  Offline OP
NJ central
Thats what I thought at first but splines look great. The new yoke goes on less than the other and the stk one in my junk pile goes on great.
Re: Driveshaft Length Help With Caltracs [Re: Scamp408] #1402920
03/23/13 12:11 PM
03/23/13 12:11 PM
Delray beach, Florida
P
Performance Only Offline
P
Are all the yokes the same length and have you measured the actual depth of the internal splines
machine shop owner and engine builder
Re: Driveshaft Length Help With Caltracs [Re: Performance Only] #1402921
03/23/13 04:30 PM
03/23/13 04:30 PM
NJ central
Scamp408 Offline OP
Scamp408  Offline OP
NJ central
All are about same length/depth. The 2 newer ones are the same make.
