Re: Driveshaft Length Help With Caltracs
[Re: mopar dave]
#1402914
03/18/13 04:44 PM
03/18/13 04:44 PM
Posts: 15,487 Florida
scratchnfotraction
I had 1 1/4" of shaft sticking out the end of the trans housing. if I had 1" of yoke to housing clearance the shaft would be bottomed out in the yoke or pretty close to it.
In this case I would slide yoke in till it bottoms out,now measure from center of cap to center of cap,then subtract 1" from your measurement.
[Re: scratchnfotraction]
#1402915
03/18/13 05:57 PM
03/18/13 05:57 PM
Posts: 2,709 NJ central
Scamp408
NJ central
I measured it all up and I have aprox 1in give or take a little with my DS. I went to where I bought the shaft sometime ago and they say bottom yoke,pull out and inch than measure center to center. The newer yoke will not go in all the way but if I force it I am sure it would. I cant see any twisted splines but something is in there. The way it was I only had 1/2" of slip.
[Re: Scamp408]
#1402918
03/23/13 11:58 AM
03/23/13 11:58 AM
Posts: 1,855 Staten Island N.Y.
Dap
Staten Island N.Y.
I twisted the spline in my 7290 yoke and replaced it with a MW 1350 yoke along with a new shaft.
PRH446 10.084 @ 135.21 mph N/A through chambered mufflers,3300lbs. Stock stroke wedge
