Is it ok to use different brand of reducer? #1402795
03/15/13 02:34 PM
03/15/13 02:34 PM
U.S.
basik Offline OP
basik  Offline OP
U.S.
I will be using ppg paint and hardener. I have a different brand of reducer and I'm wondering if it's ok to use that?
Re: Is it ok to use different brand of reducer? [Re: basik] #1402796
03/15/13 02:45 PM
03/15/13 02:45 PM
A collage of whims
topside Online content
topside  Online Content
A collage of whims
Better to stay "within the system" as that's how paint products are developed & tested. That said, I know that you can use certain DuPont reducers with Standox paint products, and plenty of people do mix brands. You might try painting something and see if you get good results.
Re: Is it ok to use different brand of reducer? [Re: basik] #1402797
03/15/13 03:45 PM
03/15/13 03:45 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
No I wouldn't. I have used different brand products on top of one another, but never have mixed brands when mixing paint.
I bet some one will come on here and say they have done it and it won't surprise me, but I won't ever take that chance because paint and prep work cost way too much today.
Re: Is it ok to use different brand of reducer? [Re: Challenger 1] #1402798
03/15/13 03:48 PM
03/15/13 03:48 PM
northwest USA
N
NANKET Offline
NANKET  Offline
N
northwest USA
Are you a gambler? As already stated, paint is already too expensive to take it back off and start over. How much TIME do you think that will cost you? Buying the correct reducer is the only choice.
Re: Is it ok to use different brand of reducer? [Re: NANKET] #1402799
03/15/13 04:14 PM
03/15/13 04:14 PM
Wisconsin
Aero426 Offline
Aero426  Offline
Wisconsin
The right reducer is cheap compared to the rest of the paint products you're buying.
Re: Is it ok to use different brand of reducer? [Re: Aero426] #1402800
03/15/13 05:14 PM
03/15/13 05:14 PM
South Dakota
hotairballoonpilot Offline
South Dakota
Gary I will be that guy! What brand of reducer are you going to use? Reason I ask is this. Transtar reducers are suppose to be equal to DT reducers. I have sprayed a lot of Transtars basecoat and they say to use either thier reducers or DT or a urethane reducer BUT NOT shop line reducer. I have been in a pinch and used DT reducer in shoplines primers before. Now would I use Transtars reducers or shopline reducers in say Ppg colors or clears. Nope. Would I used DT REDUCERS in Transtar clears if it called for it(which they don't btw) nope. Only time is in thier base coats and that's coming from their tech guys as well as district rep. Not had any issues with that. Now I can clearly see PPG rep telling you noway can you do that and would tell you DT and shopline reducers are different animals and not to intermix them. Best advice is to keep in the system.
Contact Me about AMD Prices
Re: Is it ok to use different brand of reducer? [Re: hotairballoonpilot] #1402801
03/16/13 11:41 PM
03/16/13 11:41 PM
U.S.
basik Offline OP
basik  Offline OP
U.S.
I have some PCL reducer on my shelf.
Re: Is it ok to use different brand of reducer? [Re: basik] #1402802
03/17/13 11:59 AM
03/17/13 11:59 AM
west australia
8trackbee Offline
8trackbee  Offline
west australia
if you really have to use a different reducer because your stuck, the general rule of thumb is keep basecoat reducers with basecoat and keep 2K or top coat reducers with topcoats,basecoat reducers generally dry quicker so you don't get solvent retension in your clearcoat, and topcoat reducers stay wetter so your paint has time to flow. Using a topcoat reducer in basecoat can cause what we call solvent boil( the final finish looks like it has small pimples)
Re: Is it ok to use different brand of reducer? [Re: basik] #1402803
03/18/13 12:23 AM
03/18/13 12:23 AM
South Dakota
South Dakota
Never heard of it wouldn't do it.
