Is this the Correct Kickdown for a 69 Charger 440? #1402493
03/14/13 06:27 PM
03/14/13 06:27 PM
North East
MaxHeadroom Offline OP
North East
Seems different to what I have seen, is this correct?? If no, do you have a pic of the correct setup? Thanks.
Re: Is this the Correct Kickdown for a 69 Charger 440? [Re: MaxHeadroom] #1402494
03/14/13 06:39 PM
03/14/13 06:39 PM
Rancho Cordova, California (Sa...
hemi71x Offline
hemi71x  Offline
69 would have been using the three piece kickdown linkage rods.
That's a single rod linkage, from the 70's applications.
Don't have a picture for you to compare.
But GOOGLE is your friend.
RF-4C Phantom 69-370 Zweibrucken, Germany
Re: Is this the Correct Kickdown for a 69 Charger 440? [Re: hemi71x] #1402495
03/14/13 06:43 PM
03/14/13 06:43 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
Single rod is 71 & up..... Come on Jim. your better than that.....
Re: Is this the Correct Kickdown for a 69 Charger 440? [Re: hemi71x] #1402496
03/14/13 06:48 PM
03/14/13 06:48 PM
North East
North East
Ok, is this the correct one? What color should it be painted?
Re: Is this the Correct Kickdown for a 69 Charger 440? [Re: MaxHeadroom] #1402497
03/14/13 06:55 PM
03/14/13 06:55 PM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
That is the correct one and the only part that is paintedd is the part bolted to the intake , everything else is plated in some color that is NOT orange ...
Re: Is this the Correct Kickdown for a 69 Charger 440? [Re: JohnRR] #1402498
03/14/13 07:01 PM
03/14/13 07:01 PM
North East
North East
Great, so I can leave the rest of it the color as is? Supposedly it is nickel coated.
Re: Is this the Correct Kickdown for a 69 Charger 440? [Re: MaxHeadroom] #1402499
03/15/13 08:22 AM
03/15/13 08:22 AM
Lakeland FL
floridian Offline
floridian  Offline
Lakeland FL
You need to look at a service manual.. I went through this when I misplaced my 440/727 kickdown linkage on my 67 coronet.. 3 or 4 different kickdown linkage designs depending on the engine. And its not just a rod length difference, the belcranks are different also.,.
Rick
Re: Is this the Correct Kickdown for a 69 Charger 440? [Re: floridian] #1402500
03/15/13 10:23 PM
03/15/13 10:23 PM
Western Md.
skicker Offline
"The Champ"
skicker  Offline
"The Champ"
Western Md.
Rick
What he said is correct. I used to save all of them in a box. You wouldn't believe how many different lengths of rods and bell cranks are around. I usually end up cutting them and adding a piece of round stock in the middle to get everything to work.
...FAFO...
Re: Is this the Correct Kickdown for a 69 Charger 440? [Re: skicker] #1402501
03/16/13 01:15 PM
03/16/13 01:15 PM
Vancouver, BC, Canada
rtriv Offline
rtriv  Offline
