Mechanical pump with dead head regulator
#1402479
03/14/13 05:59 PM
03/14/13 05:59 PM
Posts: 339 Gilroy,CA.
mopardude318
Gilroy,CA.
On my small block, I am using the Carter Strip Super Mechanical fuel pump: http://www.summitracing.com/parts/crt-m6270/overview/make/dodgeCurrently the fuel pressure is too high at around 11-12 PSI, pushing fuel past the needle and seat on the carb, sometimes flooding it out. I'm thinking I should use a dead head style regulator to cure this problem..what are your thoughts, and what do you recommend for a regulator? I don't wanna have to plumb a return line system. This is for a street car. Thank you.
408 Stroker 533 HP 520 FT LBS...........................1970 Dart RMS AlterKation
Re: Mechanical pump with dead head regulator
[Re: mopardude318]
#1402481
03/14/13 06:24 PM
03/14/13 06:24 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Well you pretty much answered your own question... you dont want a return line so that leaves 2 things.. get a different pump OR use a dead head regulator
