Re: The right way to install a 78 grill on an 80's truck. [Re: 4dr4x4] #1402319
03/14/13 05:23 PM
03/14/13 05:23 PM
Winnipeg, Manitoba, Canada
4dr4x4 Offline OP
mopar addict
4dr4x4  Offline OP
mopar addict
Mask the silver and spray the burgundy
Re: The right way to install a 78 grill on an 80's truck. [Re: 4dr4x4] #1402320
03/14/13 05:24 PM
03/14/13 05:24 PM
east side of Ohio
basketcase Online content
basketcase  Online Content
east side of Ohio
I tried to run a birdbath on one of my trucks and ran into that latch problem. I like the birdbath hoods but I'm more of a hood scoop guy.
beautiful truck! I have a Bird Bath on my '88, and had one on my '85 and '87. I agre on the smaller pre '80 front bumper. Love mine.
1981 Dodge D150 360 auto
Re: The right way to install a 78 grill on an 80's truck. [Re: 4dr4x4] #1402321
03/14/13 05:25 PM
03/14/13 05:25 PM
4dr4x4 Offline OP
mopar addict
4dr4x4  Offline OP
mopar addict
More time spent masking than anything else.
Re: The right way to install a 78 grill on an 80's truck. [Re: 4dr4x4] #1402322
03/14/13 05:26 PM
03/14/13 05:26 PM
4dr4x4 Offline OP
mopar addict
4dr4x4  Offline OP
mopar addict
Fenders
Re: The right way to install a 78 grill on an 80's truck. [Re: 4dr4x4] #1402323
03/14/13 05:29 PM
03/14/13 05:29 PM
4dr4x4 Offline OP
mopar addict
4dr4x4  Offline OP
mopar addict
With everything painted now the fun part of putting it all back together.
Well that's about it, lots more picture but I won't bore you with the small stuff.lol
Brett did it all himself. He started on Sarurday morning, stayed up all night painting because he had to have the truck painted and out of the booth at work by Sunday night.
Re: The right way to install a 78 grill on an 80's truck. [Re: basketcase] #1402324
03/14/13 05:35 PM
03/14/13 05:35 PM
4dr4x4 Offline OP
mopar addict
4dr4x4  Offline OP
mopar addict
I really like both bumpers, I have the corect one one my step side.
Re: The right way to install a 78 grill on an 80's truck. [Re: 4dr4x4] #1402325
03/14/13 07:56 PM
03/14/13 07:56 PM
Chilliwack B.C. Canada
RUNCHARGER Offline
RUNCHARGER  Offline
That is a great looking truck. I'm okay with the 81-93's but they look like dog crap compared to a 77-78.
Sheldon
Re: The right way to install a 78 grill on an 80's truck. [Re: 4dr4x4] #1402326
03/14/13 07:58 PM
03/14/13 07:58 PM
Truckville, the capital of NY
85_Ram_4speed Offline
I didn't realize it was burgundy. I thought it was black and silver. That must look freakin' awesome out in the sunlight. Very nice job indeed.
I can not wait to do this to mine, I have only had the pieces to do it for 6+ years now.
Outcast Dodge guy.
Re: The right way to install a 78 grill on an 80's truck. [Re: 85_Ram_4speed] #1402327
03/14/13 11:10 PM
03/14/13 11:10 PM
Manitoba, Canada
secret indy Offline
secret indy  Offline
Manitoba, Canada
There is quite a bit of difference in the shape of the fenders between 70's and 80's. That's the reason for changing the whole front section of the fender. Once this was changed everything else bolted on in the correct factory possition. No more modifying was necessary. Trust me, I mulled over a lot of different options for this modification. In my opinion, this was the easiest way to get the end result.
Brett
Re: The right way to install a 78 grill on an 80's truck. [Re: secret indy] #1402328
03/15/13 11:46 AM
03/15/13 11:46 AM
east side of Ohio
east side of Ohio
wow, didn't relize the fender shape was that different. beautiful job!
Re: The right way to install a 78 grill on an 80's truck. [Re: basketcase] #1402329
03/15/13 03:53 PM
03/15/13 03:53 PM
Kansas
cascius Offline
cascius  Offline
Kansas
I have a neighbor who is in the middle of doing this same conversion right now. He ended up using the entire front clip from a '79. He had to do some modification to the headlight area but other than that most of it was a bolt on deal. He did have to swap the doors too though because one of them had an extra body line (can't remember if it was the newer truck or the old truck).
Re: The right way to install a 78 grill on an 80's truck. [Re: cascius] #1402330
03/15/13 09:39 PM
03/15/13 09:39 PM
Central Utah
Mopargnome Offline
Mopargnome  Offline
Central Utah
That's awesome! I have wanted to use the older wheel flares/openings grafted onto later 80's fenders. Nice truck!
Re: The right way to install a 78 grill on an 80's truck. [Re: secret indy] #1402331
03/16/13 09:10 AM
03/16/13 09:10 AM
Brett
You did an excellent job for sure and the truck looks fantastic.
This is my experience so far though just to throw it out there for others.
With that said, there are a thousand ways it could be done. For the guys on here that look at that and go-- oh my, that is just to far off to make it work any other way---well, its not. I do believe the picture is a little deceiving however. The farther back you cut into the fender the worse the mismatch is going to be due to the body lines. So I personally don't believe the picture as I tried a '78 grill on my truck with the '85 fenders and core support still in place. I noted it was off a little on the top corners but matched pretty darn good the rest of the fender. No far worse than any production vehicle in my opinion. Some nip and tuck and weld on that top area of the fender would get you the right contour to match.
I did not try the lower filler piece though and I do believe the only way that is ever going to be right is to splice in the fender section there.
When I finally do get around to doing my swap I too will post my findings, This was definatly one way I wondered about and it definatly shows it can be done. And the best part as mentioned about it, is that every thing will just drop in and bolt up. Again, kudo's to you and I must say, you had it done in record time to boot. And yes, I believe you did it by far the most correct way.
Outcast Dodge guy.
Re: The right way to install a 78 grill on an 80's truck. [Re: 85_Ram_4speed] #1402332
03/16/13 10:36 AM
03/16/13 10:36 AM
S.E. South Dakota !
bigdad Offline
Still Posting A Lot
bigdad  Offline
Still Posting A Lot
S.E. South Dakota !
Brett , that is an incredible job
Two thumbs way up
You are talented !
I have a 89, and really don't like that front myself
I prefer the 84-85 look
Looked for a 72-76 2wd shortbox and found this
Re: The right way to install a 78 grill on an 80's truck. [Re: bigdad] #1402333
03/16/13 12:34 PM
03/16/13 12:34 PM
4dr4x4 Offline OP
mopar addict
4dr4x4  Offline OP
mopar addict
That's a nice truck. If you like the 81-85 grill better it's very easy to install, just changer the rad support and your good to go. I did it the other way around, my green truck is an 81 and I wanted to install an 87 grill. I took everything off and set the new grill on the truck and it would not fit right. The headlights were moved over just a bit so I had to change the support & the filler panel to make it work.
Re: The right way to install a 78 grill on an 80's truck. [Re: 4dr4x4] #1402334
03/17/13 07:03 PM
03/17/13 07:03 PM
S.E. South Dakota !
bigdad Offline
Still Posting A Lot
bigdad  Offline
Still Posting A Lot
S.E. South Dakota !
Yes, its really clean ..
If I end up keeping it, I might just do all that work to put a different front on it
Re: The right way to install a 78 grill on an 80's truck. [Re: bigdad] #1402335
03/17/13 07:37 PM
03/17/13 07:37 PM
RUNCHARGER Offline
RUNCHARGER  Offline
I like this look too!
Sheldon
Re: The right way to install a 78 grill on an 80's truck. [Re: RUNCHARGER] #1402336
03/18/13 12:58 PM
03/18/13 12:58 PM
4dr4x4 Offline OP
mopar addict
4dr4x4  Offline OP
mopar addict
I have always wanted one of those. There is a mid 70's 4x4 one of these (very rare) that has been sitting behind a warehouse in Winnipeg for years and they won't sell it. I like the fenders, good for big tires.
