How my friend installed a 78 grill on an 80's truck. #1402299
03/14/13 04:31 AM
03/14/13 04:31 AM
Winnipeg, Manitoba, Canada
4dr4x4 Offline OP
mopar addict
4dr4x4  Offline OP
mopar addict
My friend Brett & I traded trucks last summer. He had just finished a frame off rebuild on his truck and was looking for his next project. He always liked my 1980 crew cab and ask me if I would like to trade trucks. Long story short I could not pass up a truck with a 37" tires, a 440 motor and fresh paint. This truck started with a 2wd body and a 4x4 frame he got from me.
Brett never liked the 80's grills as much as the 78 so when he told me he was thinking of cutting the front end off a 78 and welding it on his truck I thought he was nuts.lol Just kidding, if Brett says he's going to do something it will be done and done right. As you can see this was no small job.
I'm posting this a 2am so I may not get all the pictures up to night.
Re: The right way to install a 78 grill on an 80's truck. [Re: 4dr4x4] #1402300
03/14/13 04:36 AM
03/14/13 04:36 AM
4dr4x4 Offline OP
mopar addict
4dr4x4  Offline OP
mopar addict
This is before he started on the body work. It was a good looking truck even before the new grill & paint.
Re: The right way to install a 78 grill on an 80's truck. [Re: 4dr4x4] #1402301
03/14/13 04:41 AM
03/14/13 04:41 AM
4dr4x4 Offline OP
mopar addict
4dr4x4  Offline OP
mopar addict
First he had to find a 78 cradle and a set of 70's fenders that had good fronts on them. Then mark the truck for surgery.
Re: The right way to install a 78 grill on an 80's truck. [Re: 4dr4x4] #1402302
03/14/13 04:50 AM
03/14/13 04:50 AM
4dr4x4 Offline OP
mopar addict
4dr4x4  Offline OP
mopar addict
Remove the front of the fenders with a cut off wheel.
Re: The right way to install a 78 grill on an 80's truck. [Re: 4dr4x4] #1402303
03/14/13 04:53 AM
03/14/13 04:53 AM
4dr4x4 Offline OP
mopar addict
4dr4x4  Offline OP
mopar addict
Then cutting and test fitting the 70's fender parts.
Re: The right way to install a 78 grill on an 80's truck. [Re: 4dr4x4] #1402304
03/14/13 04:55 AM
03/14/13 04:55 AM
4dr4x4 Offline OP
mopar addict
4dr4x4  Offline OP
mopar addict
Making sure everything lines up right and then the welding.
Re: The right way to install a 78 grill on an 80's truck. [Re: 4dr4x4] #1402305
03/14/13 05:10 AM
03/14/13 05:10 AM
4dr4x4 Offline OP
mopar addict
4dr4x4  Offline OP
mopar addict
Last one tonight.
Re: The right way to install a 78 grill on an 80's truck. [Re: 4dr4x4] #1402306
03/14/13 05:14 AM
03/14/13 05:14 AM
Granite Bay CA
Kern Dog Offline
Striving for excellence
Kern Dog  Offline
Granite Bay CA
I have never looked very close at the 80 and newer truck fenders. The flat spot at the front isn't compatible with the back side of the grille? I'm sure that he didn't just cut and weld for fun. Without seeing both models of fenders up close I wonder why the stock black fenders couldn't have had brackets added instead of the cut and patch tactic. This is no way a form of criticism, just curious about the method here.
Re: The right way to install a 78 grill on an 80's truck. [Re: Kern Dog] #1402307
03/14/13 05:30 AM
03/14/13 05:30 AM
4dr4x4 Offline OP
mopar addict
4dr4x4  Offline OP
mopar addict
A Lot of things are different, 78 cradle won't fit the 81 and up fenders and if you don't use the 70's cradle headlights are in the wrong place and the hood & valance won't work. He is a welder by trade but this was the first real body work he has tried. It only took him two afternoons to cut and weld up the fenders.
Re: The right way to install a 78 grill on an 80's truck. [Re: 4dr4x4] #1402308
03/14/13 06:13 AM
03/14/13 06:13 AM
Granite Bay CA
Kern Dog Offline
Kern Dog  Offline
Granite Bay CA
By cradle are you referring to the radiator/core support?
If so, I can see that the square headlight design would clash with the 72-78 round style.
Re: The right way to install a 78 grill on an 80's truck. [Re: Kern Dog] #1402309
03/14/13 07:33 AM
03/14/13 07:33 AM
Truckville, the capital of NY
85_Ram_4speed Offline
Funny, This is just about what I had in mind to do up mine. I am not positive, but I believe you can get away with not going up the entire side of the fender. I believe the area where the lower filler panel fits does indeed to be spliced in, but from what I can tell, the upper outside corner of the fender just needs to be massaged to fit the grill.
And again, I haven't test fitted my core support in the truck yet, But I do not beleive there was any huge differences in the mounting flanges to the fenders when I laid an '89 core support on top of a '78 core support. I think at most it was maybe some trimming and relocation of fender bolt holes either in the fender or core support.
I should really write this stuff down when I do things like this as I am much more forgetful as time marches on, LOL
Outcast Dodge guy.
Re: The right way to install a 78 grill on an 80's truck. [Re: Kern Dog] #1402310
03/14/13 12:01 PM
03/14/13 12:01 PM
4dr4x4 Offline OP
mopar addict
4dr4x4  Offline OP
mopar addict
We call them rad cradles (must be a Canadian thing.lol). I'm sure there are many different ways to make this fit. I'm just showing you how he did it. He loves welding and it's easy for him. What Brett wanted to do was make the truck look like it rolled out of the factory with that gill, and it does.
Re: The right way to install a 78 grill on an 80's truck. [Re: 4dr4x4] #1402311
03/14/13 12:14 PM
03/14/13 12:14 PM
Iowa
76dodgeboy Offline
76dodgeboy  Offline
Iowa
The Birdbath hood will fit 81-93 trucks. Only thing that needs addressed is the hood latch.
Re: The right way to install a 78 grill on an 80's truck. [Re: 76dodgeboy] #1402312
03/14/13 12:39 PM
03/14/13 12:39 PM
ME
79machocharger Offline
ME
Looks a hundred times better with that grill, very cool. Now just get him to add pre 80 bumpers to it.
Re: The right way to install a 78 grill on an 80's truck. [Re: 79machocharger] #1402313
03/14/13 12:56 PM
03/14/13 12:56 PM
4dr4x4 Offline OP
mopar addict
4dr4x4  Offline OP
mopar addict
It's my truck now and I like the bigger bumpers on a big truck. I tried a 70's ramcharger bumper on the back but it made the truck look to small. It looked like a pea on a drum.lol
Re: The right way to install a 78 grill on an 80's truck. [Re: 76dodgeboy] #1402314
03/14/13 01:03 PM
03/14/13 01:03 PM
4dr4x4 Offline OP
mopar addict
4dr4x4  Offline OP
mopar addict
I tried to run a birdbath on one of my trucks and ran into that latch problem. I like the birdbath hoods but I'm more of a hood scoop guy.
Re: The right way to install a 78 grill on an 80's truck. [Re: 4dr4x4] #1402315
03/14/13 03:48 PM
03/14/13 03:48 PM
Hartselle AL
67MIke Offline
67MIke  Offline
Hartselle AL
It looks sharp.....nice
Re: The right way to install a 78 grill on an 80's truck. [Re: 4dr4x4] #1402316
03/14/13 04:52 PM
03/14/13 04:52 PM
4dr4x4 Offline OP
mopar addict
4dr4x4  Offline OP
mopar addict
Ready for primer and blocking
Re: The right way to install a 78 grill on an 80's truck. [Re: 4dr4x4] #1402317
03/14/13 05:19 PM
03/14/13 05:19 PM
4dr4x4 Offline OP
mopar addict
4dr4x4  Offline OP
mopar addict
In the booth for the first color
Re: The right way to install a 78 grill on an 80's truck. [Re: 4dr4x4] #1402318
03/14/13 05:20 PM
03/14/13 05:20 PM
Near Reading PA USA
pinkduster Offline
pinkduster  Offline
Near Reading PA USA
Wow, seriously, that's a nice truck you have there!
