tranny trouble #1401805
03/13/13 08:06 AM
03/13/13 08:06 AM
central illinois
65dodgebob Offline OP
central illinois
Buddy has a 2000 ram 1500 with 5,2. Auto trans is shifting ok when cold then as soon as its up to temp trans wont shift into next gear without reving engine to 3 grand or more. Is this trans history or is there a fix? We already changed fluid filter and did band adjustment to no avail thanks!o.
Re: tranny trouble [Re: 65dodgebob] #1401806
03/13/13 09:27 AM
03/13/13 09:27 AM
Weatherford Texas
Greg Ducato Offline
Greg Ducato  Offline
Weatherford Texas
Sounds like an output speed sensor or governor pressure sensor/switch, it would be wise to have a qualified shop scan and check this before you start replacing parts, could save time and money
Re: tranny trouble [Re: Greg Ducato] #1401807
03/13/13 10:47 AM
03/13/13 10:47 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
Also make sure nothing is causing the trans throttle pressure control to stick causing high tranny throttle pressure which will make the shifts points much higher. That should be cable controlled so make sure its not binding when its warm and check the lever on the trans for sticking. Many times if it has a shift problem in more then one gear it can be trans throttle press related. Ron
Re: tranny trouble [Re: 65dodgebob] #1401808
03/16/13 11:20 AM
03/16/13 11:20 AM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
I saw the thread title and thought you'd been hanging out in the wrong neighborhood.
- Stu Harmon
