V8 Dakota motor mounts ??? 318 vs 360
#1401629
03/12/13 11:18 PM
03/12/13 11:18 PM
Posts: 3,449 Gateway to the West.
hemi_harvester
I have done some checking online and it looks like 318 and 360 motor mounts are different ? can you tell me what the difference is. I'm buying a Dakota that had a 360 LA in it, and I'm planning on running a 318 LA , is there a easy fix ?
There comes a time in life, when you walk away from all the drama & people who create it. You surround yourself with people who make you laugh, forget the bad, and focus on the good.
Re: V8 Dakota motor mounts ??? 318 vs 360
[Re: hemi_harvester]
#1401630
03/13/13 02:26 AM
03/13/13 02:26 AM
Posts: 12,422 Kalispell Mt.
HotRodDave
Kalispell Mt.
magnum or LA 318?
If it is a magnum 318 then you just get any Dakota V6 or V8 mounts and bolt it in.
If you are gonna put in a 318 LA then you can widen the home made mounts you are gonna find in there (unless someone I am unaware of is making LA Dakota mounts).
[Re: HotRodDave]
#1401631
03/13/13 08:33 AM
03/13/13 08:33 AM
Posts: 21,345 Marysville, O-H-I-O
70Cuda383
Marysville, O-H-I-O
what year dakota? were the early years of the truck using LA motors?
if it's a Magnum motor, (and still has a Magnum motor, and not a custom LA motor swap) then the motor mounts are all the same...mostly.
I took a Magnum 318 out of my truck, and I put a Magnum 360 in, using the same mounts. the blocks are identical on the outside.
where you can run into differences, is from a 2wd to a 4wd truck. due to suspension differences, and frame differences, there are also some differences in the motor mounts from 2wd to 4wd trucks. (2wd trucks use a coil spring up front, 4wd trucks use torsion bars, and obviously, 4wd trucks have the front axle when 2wd just has spindles and control arms)
more information is needed to help answer your question. what year dakota, and does it have the original motor set-up, or did someone do some custom fabrication to put an LA motor in.
**Photobucket sucks**
[Re: 70Cuda383]
#1401632
03/13/13 12:32 PM
03/13/13 12:32 PM
HotRodDave
Kalispell Mt.
91 was the only year dodge put LAs in the Dakotas, that block (318 only) was only used in the Dakota and has the 3 bolt holes on the side for the motor mount instead of the ears, no other LA block bolts in using the factory mounts, someone had to make there own mounts or buy some from an aftermarket company. If you are gonna put a 318 LA in you will need the 91 only 318 Dakota pan, good luck finding one
[Re: Golden-Arm]
#1401636
03/13/13 11:12 PM
03/13/13 11:12 PM
HotRodDave
Kalispell Mt.
I did say it was the only year dodge put them in there.
What kind of mounts did Shelby make to put them in there?
[Re: Golden-Arm]
#1401638
03/14/13 02:06 AM
03/14/13 02:06 AM
HotRodDave
Kalispell Mt.
No! a truck pan is not a truck pan, there is no way no how a ram/van/grand cherokee pan is gonna fit in my 2wd 90 or 4wd 93, the sump is way to wide front to back and wants to ocupy the same space as the diff on a 4wd and the steering rack on a 2wd. The dak pan has a tall skinny sump at the very rear of the pan.
[Re: cheapracer]
#1401641
03/16/13 01:40 PM
03/16/13 01:40 PM
HotRodDave
Kalispell Mt.
All magnum blocks have both motor mounts right through the end of production in the early 2000s. A regular truck pan WILL NOT FIT ! Also there were NO V8s in 1990 Dakotas.
[Re: cheapracer]
#1401645
03/18/13 04:10 PM
03/18/13 04:10 PM
HotRodDave
Kalispell Mt.
Just tried it (97 ram 5.9 and pan)in my 90 dakota like 4 days ago and the regular truck pan sits right on the k frame holding the engine about 5 inches up. I did not take pictures but trust me there was no way no how it was going. Now the engine is sitting in there like a glove with a pan from a 99 Durango and the factory V6 mounts. I tried it last fall in a 4x4 and it was doing the same thing only it was the differential trying to occupy the same space.
[Re: 70Cuda383]
#1401646
03/18/13 04:15 PM
03/18/13 04:15 PM
HotRodDave
Kalispell Mt.
360 pans fit all magnum motors 5.2 and 5.9 just certain ones fit certain chassis.
