hyd flat tappet in Magnum blk #1401561
03/12/13 09:55 PM
03/12/13 09:55 PM
Bama
Randy.. Offline OP
Randy..  Offline OP
Bama
whats needed to run a hyd flat in a magnum block? other than the cam/lifters just push rods?
Re: hyd flat tappet in Magnum blk [Re: Randy..] #1401562
03/12/13 10:34 PM
03/12/13 10:34 PM
Indy
moparman89 Offline
moparman89  Offline
Indy
That and the right cam bolt/eccentric if you need one.
School of Automotive Machinists Racing
Re: hyd flat tappet in Magnum blk [Re: moparman89] #1401563
03/12/13 11:58 PM
03/12/13 11:58 PM
Bama
Randy.. Offline OP
Randy..  Offline OP
Bama
thank's
Re: hyd flat tappet in Magnum blk [Re: Randy..] #1401564
03/13/13 09:01 AM
03/13/13 09:01 AM
Guitar Jones Offline
You have to grind the tops of the lifters bores for pushrod clearance if you are using a W series head.
'74 W200 Crew Cab 360, NV4500, D44, D60 and NP205 divorced transfer case. Rear disc and hydroboost coming soon!
Re: hyd flat tappet in Magnum blk [Re: Guitar Jones] #1401565
03/13/13 02:46 PM
03/13/13 02:46 PM
Bama
Randy.. Offline OP
Randy..  Offline OP
Bama
stk block and heads just going flat tappet, "cheap"
Re: hyd flat tappet in Magnum blk [Re: Randy..] #1401566
03/19/13 03:08 AM
03/19/13 03:08 AM
Las Vegas, NV
dodgeboy11 Offline
dodgeboy11  Offline
Las Vegas, NV
It may work with stock magnum heads, but the pushrod tube in a magnum R/T head needs to be ground or the pushrods won't clear.
