Fixture for an assembled Engine/Trans/K-member/Etc. #1401513
03/12/13 09:33 PM
03/12/13 09:33 PM
Spokane Washington
ScottSmith_Harms Offline OP
Mr Wizzard
Mr Wizzard
Spokane Washington
The title says it all, what are your favorite designs?
Re: Fixture for an assembled Engine/Trans/K-member/Etc. [Re: ScottSmith_Harms] #1401514
03/12/13 10:00 PM
03/12/13 10:00 PM
INDIANA
P
Paul Jacobs Offline
Paul Jacobs  Offline
P
INDIANA
Scott,
I don't know of any pre-made but this is what I built. It has half circle pads that the K member sits on. The arms are adjustable so it will work on A/B/E bodies. The rear has a jack pad that is also adjustable side to side & front to back. You wouldn't have to go to such extent but just an idea.
Re: Fixture for an assembled Engine/Trans/K-member/Etc. [Re: Paul Jacobs] #1401515
03/12/13 10:06 PM
03/12/13 10:06 PM
Round Lake Beach, Illinoisy
Rhinodart Offline
Rhinotruck
Rhinodart  Offline
Rhinotruck
We had some just like that at Nostalgia Lane, had pins that the k-frame sat in and a stand for the trans just like what is shown, even the jack was the same. Ours had rubber tires though...
JB Rhinehart, Realist
A-Body's RULE!
Re: Fixture for an assembled Engine/Trans/K-member/Etc. [Re: ScottSmith_Harms] #1401516
03/12/13 10:07 PM
03/12/13 10:07 PM
Benton, IL.
DaveRS23 Offline
Special needs idiot
DaveRS23  Offline
Special needs idiot
Benton, IL.
Try uscartool.com
They have a K frame stand.
Master, again and still
Re: Fixture for an assembled Engine/Trans/K-member/Etc. [Re: ScottSmith_Harms] #1401517
03/12/13 10:08 PM
03/12/13 10:08 PM
Morristown Tn.
71birdJ68 Offline
71birdJ68  Offline
Morristown Tn.
U.S. Cartool has them, but at $400 I'm gonna make my own.
Re: Fixture for an assembled Engine/Trans/K-member/Etc. [Re: 71birdJ68] #1401518
03/12/13 10:21 PM
03/12/13 10:21 PM
White Plains, NY
VCODE Offline
VCODE  Offline
White Plains, NY
Scott,
check your email
Bob
Mom & Dad let me buy a brand new 70 Challenger R/T 440 Six-Pack Super Trac Pack when I was 17
(Robert what is a 440 Six-Pack)
Re: Fixture for an assembled Engine/Trans/K-member/Etc. [Re: VCODE] #1401519
03/12/13 10:22 PM
03/12/13 10:22 PM
White Plains, NY
VCODE Offline
VCODE  Offline
White Plains, NY
2
Re: Fixture for an assembled Engine/Trans/K-member/Etc. [Re: VCODE] #1401520
03/19/13 02:02 PM
03/19/13 02:02 PM
Tampa, FL
tpabayflyer Offline
tpabayflyer  Offline
Tampa, FL
You Sir are a certified genius!! Thank you for the idea!!! TBF
71 Challenger 528 Hemi project
09 Gr Cherokee 5.7 hemi in da house!!
Re: Fixture for an assembled Engine/Trans/K-member/Etc. *DELETED* [Re: ScottSmith_Harms] #1401521
03/19/13 03:52 PM
03/19/13 03:52 PM
Phoenix - surface of the sun
nomore65BelvJim Offline
Post deleted by ScottSmith_Harms
And quoting not_a_charger:
"You're awesome! Great job! Keep up the good work!"
Re: *DELETED* [Re: ScottSmith_Harms] #1401522
03/19/13 07:46 PM
03/19/13 07:46 PM
Kelowna, B.C. Canada
DPelletier Offline
DPelletier  Offline
Scott,
I have one you can borrow/have if you are up my way. PM me if you need it.
1970 Super Bee 440 Six Pack 1974 'Cuda 2008 Ram 3500 Diesel 2006 Ram 3500 Diesel 2004.5 Ram 2500 Diesel 2003 Ram 3500 Diesel 2006 Durango Limited [url] http://1970superbee.piczo.com [/url]
Re: Fixture for an assembled Engine/Trans/K-member/Etc. *DELETED* [Re: nomore65BelvJim] #1401523
03/19/13 07:48 PM
03/19/13 07:48 PM
jersey shore
flypaper Offline
I hate Texas
flypaper  Offline
I hate Texas
jersey shore
Re: Fixture for an assembled Engine/Trans/K-member/Etc. *DELETED* [Re: flypaper] #1401524
03/19/13 09:08 PM
03/19/13 09:08 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Thanks Dave, I might take you up on that, I have a trip planned up there in a couple weeks. Also, thanks to those who've offered help on this thread, I appreciate it.
Re: Fixture for an assembled Engine/Trans/K-member/Etc. [Re: VCODE] #1401525
03/24/13 09:39 AM
03/24/13 09:39 AM
St Louis, MO 63026
convx4 Offline
convx4  Offline
St Louis, MO 63026
I hated the fact that my cherry picker took up so much shop space, and it was only used for one thing.
Before I got my two post lift I was able to used it to drop the body on my engine and transmission. I took an extra set of front bumper brackets and extended them. I then added a square bare between them. My engine stand base with a sheet of plywood on it held the k member and engine/transmission. Using the picker to lift the body up I was able to roll the engine/transmission/k member under the car. Then a floor jack was used on the tail of the transmission, for adjustment. It worked great.
Now that I have a two post lift I added a HF transmission jack adapter on top above the hook on the cherry picker. Using an appropriate sized hole saw for the T. adapter post I also then drilled and taped a hole for a hold down bolt. This way it can be removed if need be. This is a nice sturdy safe way to remove a transmission with the car way up high on a lift on the cheep.
Re: Fixture for an assembled Engine/Trans/K-member/Etc. [Re: convx4] #1401526
03/24/13 09:53 AM
03/24/13 09:53 AM
SE PA
cudaize Offline
cudaize  Offline
SE PA
Here's pictures of one I built out of 6x6's
Re: Fixture for an assembled Engine/Trans/K-member/Etc. [Re: cudaize] #1401527
03/24/13 09:53 AM
03/24/13 09:53 AM
SE PA
cudaize Offline
cudaize  Offline
SE PA
another
Re: Fixture for an assembled Engine/Trans/K-member/Etc. [Re: cudaize] #1401528
03/24/13 09:56 AM
03/24/13 09:56 AM
SE PA
cudaize Offline
cudaize  Offline
SE PA
I was putting this Challenger together as a driver is why I didn't take the time to clean the transmission etc. I saw this as an oppurtunity to practice for doing the same thing on my Cuda.
Re: Fixture for an assembled Engine/Trans/K-member/Etc. [Re: cudaize] #1401529
03/24/13 06:20 PM
03/24/13 06:20 PM
central P.A.
HEMIDOG 70 Offline
HEMIDOG 70  Offline
central P.A.
Here is the us car tool cart. It worked good,but you must watch to k frame angle when it sets on the cart. It can rock forward or back a little. this can play havoc with header fitment etc damhik.
Re: Fixture for an assembled Engine/Trans/K-member/Etc. [Re: HEMIDOG 70] #1401530
03/24/13 08:20 PM
03/24/13 08:20 PM
ky hills
thehemikid Offline
thehemikid  Offline
ky hills
I stole the wheels off my safeway scaffold & made one that will disassemble for floor space when done. I think I used 55-7 chevy body mounts for softeners. This is a dummy motor mock-up. It still needs a rear scissor jack for the trans. There's a welded bolt with threads through the softener, through the oval hole in the K-member, with a washer & finger tight nut.
Not the best design in the world & its a bit tall, but it'll work,.......I think ... ......haven't tried it yet.
Coming soon to a theater near me!
Re: Fixture for an assembled Engine/Trans/K-member/Etc. [Re: thehemikid] #1401531
03/24/13 08:57 PM
03/24/13 08:57 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Some very nice examples, thanks for sharing! I'm a US Cartools vendor but have only carried thier frame connectors and drive shaft loops. I haven't seen one of the engine carts they introduced in person yet. Is there anything about it you'd change? Has anyone seen any examples of any other competitors product out there?
Re: Fixture for an assembled Engine/Trans/K-member/Etc. [Re: ScottSmith_Harms] #1401532
03/24/13 09:14 PM
03/24/13 09:14 PM
california
Mr D21 Offline
Mr D21  Offline
california
this works great for me -
