Re: What valve stem seals ( eddy heads )
[Re: VernMotor]
#1401329
03/12/13 02:52 PM
03/12/13 02:52 PM
Posts: 3,544 Syracuse,NY
CompWedgeEngines
Syracuse,NY
Go with viton metal clad, NOT Teflon. If you need some, let me know.
TT
RIP Monte Smith
[Re: VernMotor]
#1401333
03/12/13 04:41 PM
03/12/13 04:41 PM
Posts: 3,675 Akron, Ohio U.S.A.
roadhazard
Akron, Ohio U.S.A.
Check out my catalog Jamie
You have never sent me one ?
It's on my website ![](/ubbthreads/images/graemlins/laugh2.gif) Todd has you taken care of ![](/ubbthreads/images/graemlins/thumbs.gif)
[Re: rickraw]
#1401338
03/12/13 10:32 PM
03/12/13 10:32 PM
CompWedgeEngines
Syracuse,NY
I agree. Dry the valve stems.
RIP Monte Smith
[Re: maximum entropy]
#1401340
03/13/13 05:11 PM
03/13/13 05:11 PM
Posts: 6,531 Jacksonville, FL
Chris2581
Jacksonville, FL
We use teflon seals with no problems also,that's why I asked.
[Re: Chris2581]
#1401341
03/13/13 06:50 PM
03/13/13 06:50 PM
CompWedgeEngines
Syracuse,NY
They work sure. When you take a lot of engines apart, you get to see the difference between those and the viton style. It very apparent the dryness and actual wear on the valve stems.The valve stems often are scratched and looked like they ran dry.I will only use Viton, but will Teflon work, sure, just not for me after seeing the difference. Every engine and head I do gets viton. just my preference after years of tearing down engines and noting the difference. I used them years ago like everyone, but I feel there is a better option now. If you have good luck with those then certianly no reason to change. ![](/ubbthreads/images/graemlins/Twocents.gif)
RIP Monte Smith
[Re: CompWedgeEngines]
#1401342
03/13/13 08:04 PM
03/13/13 08:04 PM
Chris2581
Jacksonville, FL
If something works better,I'm all for it.You build more engines than I do,so I'm glad you posted why.
