Re: What plugs?!
[Re: Cab_Burge]
#1401163
03/12/13 04:13 AM
03/12/13 04:13 AM
Posts: 3,667 Arizona
Chris'sBarracuda
Arizona
I thought the 8 is colder than a 9. My 9s are still in the box. No fouling out tho isn't 10 the hottest?
No, Thumper is correct on NGK, the smaller last numbers are hotter, the bigger numbers are colder, IE a -8 is hotter than a -9. A -5 is really hot
YES..^^^Correct...NGK... -10 is coldest..
Chris..
Re: What plugs?!
[Re: Thumperdart]
#1401166
03/12/13 04:21 PM
03/12/13 04:21 PM
Posts: 2,008 Sweet Home Alabama
MRMOPAR622
Sweet Home Alabama
I have run and liked the Champion C59CX for years,I have just switch to the Autolite AR3933(same heat range) and only like them better because I can read the plugs better,than with the Champions on alcohol.No difference in ET between the 2 at all.The NGK R5671-9 is the same heat range plug,have not run them yet not sure if I will like the full length electrode.
"To Be The Man'You Have Got To Beat The Man"
"T/D and Pro-Bracket Racer"
