voltage problem.. calling all mopar nuts
#1401119
03/11/13 10:57 PM
03/11/13 10:57 PM
Posts: 256 libby mt
lifted85
libby mt
ok so I had a problem with my voltage was not charging enough so swapped in a new bwd vr, was charging at 15-16v would not drop any lower.. cleaned grounds, grinded down to metal where the vr mounts still no change, so a budy pulls a vr off 1 of his parts trucks for me to install, she's charging at 14.6. I thought problem was fixed, go for a drive an my volt gauge pegs out at 18v, I thought ok maybe it was the aftermarket gauge, because it would hit 18 then drop down to 14. so I park the truck the next day I fire it up hook my multi meter to the battery an watch the volt gauge an my multi meter an both are dead right 17v then drop to 14v.. the alt is new maybe a month or 2 old. right now I yanked the engine wire harness out and am going through it, but ya guy's got any thing else or idea's??
drive fast, drive hard, DRIVE MOPAR
Re: voltage problem.. calling all mopar nuts
[Re: lifted85]
#1401120
03/12/13 12:27 AM
03/12/13 12:27 AM
RapidRobert
The simple answer is both of the new regs could be bad. Might take voltage readings at all terminals/places & post what you get. Could swap in another alt from one of your other vehicles for a quick test in case its' field circuit is shorting out but you did say it was charging LOW & the prob really took a wrong turn when you started replacing regs. (what is a bvd reg?). This high voltage is at the alt not the batt correct? I'd take off all the field wires & with jumper wires with alligator clips I'd jump from the batt positive post (or starter relay batt stud) to either alt field & the "top" terminal on the reg and from the "side" reg terminal to the other alt field terminal and jump from the reg & alt cases to the batt neg post and from eng block to batt neg post. A 6 or 8 ga jumper from the batt positive terminal to the alt batt stud. Then see what you get for readings. gotta be either reg/wiring or terminals/alt. A bad/sulphated batt wants high voltage as it has a high resistance to being charged but as said it was LOW before the regs were changed. Holler how things turn out
[Re: 63stabamatic]
#1401123
03/13/13 05:32 PM
03/13/13 05:32 PM
Posts: 256 libby mt
lifted85
libby mt
i pulled the whole engine harness out, bought a new voltage reg conector, an am oing to go through an see if any wire's ect are cracked our fried..
[Re: lifted85]
#1401124
03/15/13 07:53 PM
03/15/13 07:53 PM
Posts: 25 Glendora, CA
MYBD318
Glendora, CA
I've seen this problem with a 74 Scamp I had. It turned out that the wire feeding the voltage regulator is also the same one that supplies the field winding. there was a substantial voltage drop in that wire and the regulator was responding accordingly by upping the voltage. I ended up boiling the water out of the battery before I was able to track it down. Mike
Still a teen just a 416
