Help! 1970 340 Exhaust Manifolds #1400782
03/11/13 10:37 AM
03/11/13 10:37 AM
South Georgia
tx9cuda Offline OP
tx9cuda  Offline OP
South Georgia
I’m installing the exhaust manifolds on my 1970 340 engine. The FSM is not clear on how to install these manifolds. I have five questions –
1. Which way do the conical washers go? (See attachment) - A or B?
2. Are the washers used at each fastener or just the ends as the FSM says?
3. Did these manifolds use a gasket other then the right side heat shield?
4. What are the torque specs?
5. Were these manifolds painted orange on the engine from the factory?
Obviously washers cannot be used with the two shoulder bolts; the mounting kit does provide enough washers to be used at all other locations.
Thanks Bryan
7621642-exhman.pdf (546 downloads)
1971 BS23H1B
Re: Help! 1970 340 Exhaust Manifolds [Re: tx9cuda] #1400783
03/11/13 10:40 AM
03/11/13 10:40 AM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
Pic A for the washers, I've only seen washers on the 2 most outer ends, 1 gasket/plug shield on drivers side
Re: Help! 1970 340 Exhaust Manifolds [Re: DAYCLONA] #1400784
03/11/13 01:17 PM
03/11/13 01:17 PM
Bethel Ct
AdamR Offline
AdamR  Offline
Bethel Ct
Manifolds were painted on the engine. Some say they were just oversprayed but I doudt the line workers cared enough to try to go around them. Im sure they were pretty much covered with paint.
Re: Help! 1970 340 Exhaust Manifolds [Re: tx9cuda] #1400785
03/11/13 02:38 PM
03/11/13 02:38 PM
MA
steve70 Offline
steve70  Offline
MA
Pic A for the washers. Washers are for studs only. Gasket on passenger side, shield on driver's side. Manifolds installed before paint.
1970 Challenger T/A 4 speed
Re: Help! 1970 340 Exhaust Manifolds [Re: steve70] #1400786
03/11/13 02:40 PM
03/11/13 02:40 PM
MA
steve70 Offline
steve70  Offline
MA
second one
Re: Help! 1970 340 Exhaust Manifolds [Re: steve70] #1400787
03/11/13 05:08 PM
03/11/13 05:08 PM
South Georgia
tx9cuda Offline OP
tx9cuda  Offline OP
South Georgia
Your pass side pic shows washers under the bolts in the center of manifold
Also where did you get those pass side gaskets?
Nice looking engine by the way!
1971 BS23H1B
Re: Help! 1970 340 Exhaust Manifolds [Re: tx9cuda] #1400788
03/11/13 05:51 PM
03/11/13 05:51 PM
MA
steve70 Offline
steve70  Offline
MA
You're correct washers everywhere except for sleeves (sorry)
The gasket is a regular fel-pro that's had the connecting section removed.
I can't take credit for the restoration. It was done by another Moparts member-Thanks Troy
Re: Help! 1970 340 Exhaust Manifolds [Re: steve70] #1400789
03/11/13 09:58 PM
03/11/13 09:58 PM
Bethel Ct
AdamR Offline
AdamR  Offline
Bethel Ct
FWIW, I just pulled the manifolds of my original 318. It had no gaskets on the passenger side.
Re: Help! 1970 340 Exhaust Manifolds [Re: AdamR] #1400790
03/11/13 10:06 PM
03/11/13 10:06 PM
Iowa
burdar Offline
Owen's Dad
burdar  Offline
Owen's Dad
Iowa
If you look at this picture(318) you can see that there aren't any washers on the center bolts. http://www.moparaction.com/Article/GROCERY_GOLD/IMG_0674_1200x900.jpg
Re: Help! 1970 340 Exhaust Manifolds [Re: burdar] #1400791
03/12/13 02:26 PM
03/12/13 02:26 PM
South Georgia
tx9cuda Offline OP
tx9cuda  Offline OP
South Georgia
From the comments on this thread plus some more research it appears that the washers are for each end of the manifold but not the center like the FSM says. Why or their purpose I don't know.
No gaskets from the factory on right side. However Fel Pro makes a gasket # MS 90460 to be used on hard to seal manifolds - old, uneven surfaces or warped.
Manifolds were painted by factory on the engine, which likely quickly burned off with use.
My
1971 BS23H1B
Re: Help! 1970 340 Exhaust Manifolds [Re: tx9cuda] #1400792
03/16/13 12:41 AM
03/16/13 12:41 AM
Cut and Shoot, TX
kentj340 Offline
kentj340  Offline
Cut and Shoot, TX
My 1969 one-owner 340 never had the exhaust manifolds off until recently. My disassembly photos show washers at each end of the manifold but not the center, as mentioned above. I believe the bolt kits for this application have 4 thick conical washers each side, bare steel. All the bolts and washers for the exhaust manifolds are bare steel, not plated.
