1963 tapered 8 3/4 axles
#1400763
03/11/13 07:45 AM
03/11/13 07:45 AM
Posts: 243 Helsinki, Finland
Anselmi
Helsinki, Finland
Does someone sell new tapered axle shafts for a '63 Sure-grip 8 3/4? Can I use "green bearings" with the original axle shafts?
'66 Plymouth '64 Dodge '63 Plymouth x 3
Re: 1963 tapered 8 3/4 axles
[Re: Anselmi]
#1400768
03/11/13 11:14 PM
03/11/13 11:14 PM
Posts: 22,696 Bitopia
jcc
Bitopia
I think I understand the interest in green bearings, but whats the reason for new tapered axles, which most do not favor? I bet there are many, including myself, that have sets laying around heading for the scrap yard.
And mine are 62's which I'm guessing are too short.
[Re: Anselmi]
#1400770
03/12/13 02:42 PM
03/12/13 02:42 PM
Posts: 25,791 Rio Linda, CA
John_Kunkel
Rio Linda, CA
On some of the aftermarket axles I've seen, the raised hub that registers the brake drum appears to be bolted on (not machined from the flange). If you have access to a lathe it would be fairly easy to machine the the hub from the tapered brake drum flange and bolt it to the new flange axle...I've thought about doing that myself just for looks.
