Re: A833 18 Spline Experts Opinion Needed Please!!!
[Re: Stanton]
#1400375
03/10/13 10:02 PM
03/10/13 10:02 PM
Posts: 2,963 Wisconsin
Stewpar
Wisconsin
A picture's worth a thousand words
I know, I know, unfortunately I didn't think about that till I got home from the shop! I was hoping someone would just say they were cut that way from the factory! If not, I will get a picture next week and post........................
Admiration For Multiple Carburetor Vehicles...
Re: A833 18 Spline Experts Opinion Needed Please!!! PIC
[Re: Stewpar]
#1400377
03/15/13 10:05 PM
03/15/13 10:05 PM
Posts: 705 USA
rftroy
USA
[Re: Stewpar]
#1400378
03/15/13 10:32 PM
03/15/13 10:32 PM
Posts: 9,436 Blair County,PA
62maxwgn
Blair County,PA
Here you go!
They're not cross cut,they are broken !
[Re: 62maxwgn]
#1400379
03/15/13 10:34 PM
03/15/13 10:34 PM
Posts: 705 USA
rftroy
USA
Yep!
Re: A833 18 Spline Experts Opinion Needed Please!!! PIC *DELETED*
[Re: Stewpar]
#1400382
03/16/13 01:12 PM
03/16/13 01:12 PM
Stewpar
Wisconsin
Post deleted by tommoparts
[Re: Stewpar]
#1400387
03/16/13 04:32 PM
03/16/13 04:32 PM
Posts: 768 Ohio
Dan Brewer
Ohio
I don't think its broke. I believe it was a bad forging to start with. I have seen this a couple times on clusters and speed gears also. Not ideal but I'm sure it was run this way for a long time. How does 3rd gear look?
That's the way I look at it also, 3rd gear is just fine. The car is going to be more or less of a trailer queen. Driven yes, but beat on, no. Do you guys think I can get away with that?
Trailer queen? Original trans with how many miles on it already? Put it back together and run it. If you were going to put 650 HP in front of it and abuse it then my opinion would be different.
[Re: MO_PA]
#1400392
03/17/13 09:32 PM
03/17/13 09:32 PM
Posts: 9,894 MI, usa
dvw
MI, usa
before I'd run it I'd carefully grind the sharp edges and smooth up the OD of the broken teeth.
I agree. Done it before on ring gear teeth with no failure. Doug
