Re: motor home 44o?
[Re: fastmark]
#1400122
03/10/13 11:18 AM
03/10/13 11:18 AM
Posts: 12,327 Benton, IL.
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
Wait a minute here.........You're saying that the 440 motor home engines have different machining or casting than other 440s? Are you sure you are not confusing some of the particulars of the industrial 413s?
The heads are a very well known non performance item. But I have built several motor home 440s, I have one stroked to 499 in my Cuda now, and have never even heard of an issue with the block mating up properly to any stock style heads. Including the Eddies I have on mine now.
Master, again and still
Re: motor home 44o?
[Re: ahy]
#1400124
03/10/13 01:58 PM
03/10/13 01:58 PM
Posts: 15,487 Florida
scratchnfotraction
my 77 MH engine in my 88 truck has the bullet nosed balencer/cast crank,452 heads,5/8" peanut spark plugs. runs great with a stock 727/3.91 sg just swaped to 3.23 with a q-jet on an rpm intake. 13mpg 10mpg with 3.91sg but lots of I am going to swap a whiplash cam in mine and go back to 3.91 for some T&T for a time slip. well thats my plan anyways. I will jump on another one if I get the chance. they are the last of the H/D stock smogger BB after all.
Re: motor home 44o?
[Re: fastmark]
#1400126
03/10/13 05:57 PM
03/10/13 05:57 PM
Posts: 18,493 Granite Bay CA
Kern Dog
Striving for excellence
Granite Bay CA
Yes they are different. If my motor was apart, I would take pictures to show you.
Why don't you go ahead and tear it down for pictures.
Re: motor home 44o?
[Re: Kern Dog]
#1400127
03/10/13 06:03 PM
03/10/13 06:03 PM
Posts: 6,444 Abilene, Texas
fastmark
Abilene, Texas
Hmmm.
Re: motor home 44o?
[Re: d-150]
#1400129
03/10/13 08:35 PM
03/10/13 08:35 PM
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
Sounds similar to the steam holes on the Hemis. I am surprised that blocking them while all the other water holes function would cause a problem.
