Re: wiring an A500
[Re: cudadan]
#1398330
03/07/13 12:08 AM
03/07/13 12:08 AM
Posts: 27,421 Balt. Md
383man
Balt. Md
Well the 91 should have the three wire Nuetral safety switch and may have a 3 wire connector on the speed sensor. The connector on the upper part of the left side should also be three wires which is the one you want. The middle wire is a 12 volt key on supply and the two outer wires are the ground circuits for the lock-up converter and the overdrive gear. The center 12 volts feeds the lock-up and overdrive solenoids and then the ground side goes out to the outer terminals on that 3 wire connector. When you ground the outer wires with 12 volts applied to the center wire it will activate the overdrive and lock-up solenoids to work. I dont remember which is which on the outer wires for the lock-up and overdrive solenoids but I can try to look it up for you. Ron
Re: wiring an A500
[Re: cudadan]
#1398332
03/07/13 10:52 AM
03/07/13 10:52 AM
Posts: 1,822 Colorado
denfireguy
Colorado
Look on this page: http://www.transmissioncenter.net/SwapInformation.htmThey have the diagrams. Unfortunately this morning, it did not load the picture with the diagram. Craig
2014 Ram 1500 Laramie, 73 Cuda Previous mopars: 62 Valiant, 65 Fury III, 68 Fury III, 72 Satellite, 74 Satellite, 89 Acclaim, 98 Caravan, 2003 Durango Only previous Non-Mopar: Schwinn Tornado
