Re: Change valve seals w/out pulling heads? [Re: KnuckleDuster] #1397829
03/16/13 12:40 PM
03/16/13 12:40 PM
What kind of rope works best for this trick?
Get 2&1/2 feet of 3/8" white nylon rope at your Ace hardware store for pennies. When done store it in a grocery plastic bag to keep it clean for the next time. As said either works fine & if you have shop air it's a bit faster & watching the rotor when turning the crank will let you find TDC the fastest. EDIT You can use your compression tester hose/14mm fitting to screw in the plug hole/connect to shop air just take the shrader valve (tire valve stem valve) out of it first
Re: Change valve seals w/out pulling heads? [Re: RapidRobert] #1397830
03/16/13 11:05 PM
03/16/13 11:05 PM
Andrews,In. U.S.of A.
67_Satellite Offline
Just finished up a ford 390 for a local friend. Broke it in on some old crower 80# seat #250 Open springs.I just ran the piston in question up to t.d.c.,pulled the "soft" spring and installed the e-head springs.The seal held the valve on the seat while I installed the new spring and ret/keepers.No rope,no air,no drama.
