Page 1 of 3 1 2 3
92 Ram. Im begging for good mechanic advice...please #139774
10/21/08 10:01 PM
10/21/08 10:01 PM
missouri, USA
moparmojo Offline OP
missouri, USA
Man, it happened again! I was driving my 92 5.2 dodge ram today making and errand and it died...in the same damn intersection it dies at every time before. Sorry for bringing this up again, some of you will recall I had this same issue a year or so back. Seems like when it is cold I have this issue. I thought the problem was gone, but apparently that is not the case.But again I don't drive it much.
Here is what happened. I got in the truck, it was probably 40 or 50 degrees out....sunny. Truck started right up. I waited a second or two then drove away from home. About 600 yards from my house, I turn on the main street and drive approximately a 1/4 to 1/2 mile. There is a slight curve in the road then I come up to the fear intersection. As I pull up to the red light, I put my foot on the brake to slow down. As I am almost at a stop I can hear the truck getting quiet then it starts to die. It dies. I crank the truck. It turns over easy, but does not start. I remember something the dealer had told me the last time this occurred. He said to push the gas pedal all the way to the floor. He said this stops new fuel from being delivered. I do this and crank the truck. A few seconds later it starts. I gas it once or twice to clear it out, then put it in drive. It dies instantly. Urrghh!. So I put my flashers on as people are honking. Im in the turn lane. Same exact spot(literally, within 10ft). I floor it and recrank. It starts. I put in drive... it dies. So I repeat. This time, I left it in park. It seems to run fine, in park. I rev the motor up, hoping it will warm up and help eliminate this issue.
(Me and the dealer have always thought it was temp related)But after paying the dealer a $1000 for multiple diagnostic sessions I am not sure. I thought the last time they got it, but was still unsure, hence the reason I only really drive it when I need to pick up lumbar or it is warm out. Anyway, I let it warm a second or two in park, rev it up, and basically dump it into drive, it chirps a little bit, almost dies, but I gased it enough to get it driving. I drive about an 8th mile and park it. Go inside for 20mins, come back out. Starts right up, and I drive home.
This really bugs me, and I can't believe I am the only one to have this issue. I want this fixed but I am tired of throwing money and parts at this problem. Please anyone knowledgable, can you please help or ask a buddy mechanic or someone. Seriously, if I could get this fixed, I would even consider shipping some beer off to someone. Feel free to ask me questions. I am mostly a "parts changer"...not a mechanic, but I can answer most things we have previously done to it before.
Re: 92 Ram. Im begging for good mechanic advice...please [Re: moparmojo] #139775
10/21/08 10:24 PM
10/21/08 10:24 PM
My 83 318(2bbl carter) acts the same way because I have no choke at the moment. When it's fully warmed up it's pretty much OK. I cant offer much help but there's been several occaisons that I just wanted to floor it & blow it up & then leave it sit & call a cab.
Re: 92 Ram. Im begging for good mechanic advice...please [Re: moparmojo] #139776
10/21/08 10:39 PM
10/21/08 10:39 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
older 5.2 - 5.9's were notorious for dist pickup plates
1st step is figure out if it's fuel or ignition problems
Re: 92 Ram. Im begging for good mechanic advice...please [Re: moparmojo] #139777
10/21/08 10:41 PM
10/21/08 10:41 PM
N
NITROUSN Offline
NITROUSN  Offline
N
I would start with reading for codes and fuel pressure readings. You may have to rig a fuel pressure guage up to monitor it when its acting up.
Re: 92 Ram. Im begging for good mechanic advice...please [Re: NITROUSN] #139778
10/21/08 11:15 PM
10/21/08 11:15 PM
Chino Valley
RodStRace Offline
RodStRace  Offline
Chino Valley
A very specfic transient issue. I'd suggest changing your routine to see if it's time, distance or road conditions. This may help pinpoint the issue.
I'd suggest finding a buddy with a scan tool to record the event. Look carefully at the fuel trim, ECT, timing, and any other voltages that change before and during this event.
My WA guess is that it sees a change in the coolant temp, changes the fuel curve and/or the idle air, and it dies.
Re: 92 Ram. Im begging for good mechanic advice...please [Re: NITROUSN] #139779
10/21/08 11:22 PM
10/21/08 11:22 PM
BROOK PARK, OH
WILD BILL Offline
WILD BILL  Offline
BROOK PARK, OH
First thing that popped into my mind was it sounds like your conver lock up isn't disengaging and it's causing your truck to act like a manual when you dont push the clutch in.
I wonder if there is a way it disable the lock up like you can do W/ a GM trans?
Or you could just try putting it in neutral the next time it feels like it's going to die.
I never had this problem nor do I know if it's even possible. Just what came to mind as I read your post.
Good luck
Re: 92 Ram. Im begging for good mechanic advice...please [Re: moparmojo] #139780
10/21/08 11:26 PM
10/21/08 11:26 PM
Atlanta
DartGTX Offline
DartGTX  Offline
Atlanta
92 Ram used an SBEC controller. ECT is on a dual range scale. At cold start it has a 4.75 - 1.25 volt range. At approx 125 degrees F, the ECT volts should have dropped to 1.25v. At this voltage the SBEC internally adds a resistor and the ECT volts JUMP UP to approx. 3.75 and then again use the 5v scale downward as the engines continues to heat up. Verify that this transition is happening at approx 125 degrees then MOVE on............
Good luck
Re: 92 Ram. Im begging for good mechanic advice...please [Re: DartGTX] #139781
10/22/08 12:38 AM
10/22/08 12:38 AM
Mission BC
10sec440 Offline
10sec440  Offline
Mission BC
If it runs fine in park but dies when you put it in gear it may be a convertor issue like wildbill says. Being a 92 you might be able to unplug the lockup solenoid near where the shift shaft goes into the transmission.
If it dies while driving or in park/neutral it is something else.If it dies while driving don't try to restart it, leave the key on (put it in park), open the hood and find the shrader valve on the fuel rail. Take the cap off and CAREFULLY push the valve in with a pen or something. If the fuel shoots directly in your eyes and all over you, its probably not a fuel pressure issue. If it barely burbles out you have a problem.
If that all checks out post a list of the stuff the shop did and I'll give you more stuff to check. HTH, Chris.
Re: 92 Ram. Im begging for good mechanic advice...pleas [Re: 10sec440] #139782
10/22/08 08:29 AM
10/22/08 08:29 AM
If it dies only when put in gear it sounds like a torque converter issue.My old 93 dakota did this and when i pulled the trans the pan was full of metal from the converter disenegrating.
Re: 92 Ram. Im begging for good mechanic advice...please [Re: 10sec440] #139783
10/22/08 08:31 AM
10/22/08 08:31 AM
Louisville, KY.
Scottmon Offline
Scottmon  Offline
Louisville, KY.
I'd really look hard at the fuel pump module. Sounds like the pump is dying.
Re: 92 Ram. Im begging for good mechanic advice...please [Re: Scottmon] #139784
10/22/08 09:22 AM
10/22/08 09:22 AM
Just South of The Motor City
limechallenger Offline
Or the filter on the pump may be plugged, after it sits for awhile the dirt moves away and it runs again ,I'd drop the tank and check for dirt in the tank,and change the pump filter! I had a similar problem with my 95 Ram!
70 T/A Challenger 78 Aspen R/T 87 Indy 500 Dakota
Re: 92 Ram. Im begging for good mechanic advice...please [Re: limechallenger] #139785
10/22/08 12:49 PM
10/22/08 12:49 PM
P
Paul_Fancsali Offline
P
It runs fine when warm or sits after driving , have you changed the intake gasket? they are noted for their leaking also and it is a bit of a long shot check the bottom of the coil if mounted in the frt of engine if it has rust it is bad get another I have had more then my share of 5.2 and 5.9 engines that had that problem
Re: 92 Ram. Im begging for good mechanic advice...please [Re: Paul_Fancsali] #139786
10/22/08 02:27 PM
10/22/08 02:27 PM
missouri, USA
missouri, USA
We previously gave the truck a tune up. New plugs, wires, cap, rotor, cleaned the throttle body, checked the wiring and connections. Looking for loose or non grounded items. Without using a wire testor hard to tell if there are any wire breaks under the wire wrap. We have changed the coolant temp sensor, ait temp sensor and Map sensor. No codes from the computer. I have thought about the intake and or head gaskets, because the dealer once said he noticed a puff of smoke during start up. I have not actually seen this, but why would he make it up. I also thought about valve seals. But again, why only when it is cold? During the summer months it drives great. I am trying to keep the truck around because it is paid for and otherwise, nice to have for hauling. I am just finishing up my garage project and am anxious to finally get back to working on my muscle cars which have been sitting for 10 years, so I don't want to spend all my free time or money on this truck. So I am stuck because the dealer can't seem to find it without breaking my bank and the issue seems complex and above my previous attempts. But someone has to know.
Re: 92 Ram. Im begging for good mechanic advice...please [Re: DartGTX] #139787
10/22/08 03:34 PM
10/22/08 03:34 PM
Omaha, Nebraska
Scott Carl Offline
Scott Carl  Offline
Omaha, Nebraska
Good luck
I have a 92 5.2 Dakota that had the same symptoms. Had to replace the black box on the fender under the hood. SBEC controller?? Anyway. after we replaced it I never had another problem
Re: 92 Ram. Im begging for good mechanic advice...please [Re: moparmojo] #139788
10/22/08 05:07 PM
10/22/08 05:07 PM
Mission BC
10sec440 Offline
10sec440  Offline
Mission BC
That cost you $1000.??? The intake gaskets or valve seals are not going to make it die on the road. You have to verify if its fuel or not. Go back and read my post again, that will determine if its fuel or not. Don't replace parts or drop the tank until you isolate the problem. It may be the computer although that year they were not bad for computers. Again, isolate the problem and go from there. I work on this stuff every day.
Re: 92 Ram. Im begging for good mechanic advice...please [Re: 10sec440] #139789
10/22/08 10:31 PM
10/22/08 10:31 PM
missouri, USA
missouri, USA
Ok, I will look at the fuel rail tomorrow for what you are talking about. Hard to test since you can never really tell when it will happen. HOwever, if I can determine your method is doable, I will try it the next time this occurs to try to help eliminate the fuel issue. But to me is always acts like it is flooding out. So I have always kind of believed it was some sort of electrical issue. One that tells the computer to take two reading then calculate the fuel needed. In error of course. I wonder if there is a way to test the truck computer? I think they want like $300 for a new computer. They are not cheap, but if I knew that was the problem, I would happily spend the money. Converter is an interesting idea also. First I have heard of it. Might be another possible area to focus on.
Re: 92 Ram. Im begging for good mechanic advice...please [Re: moparmojo] #139790
10/22/08 10:51 PM
10/22/08 10:51 PM
N
NITROUSN Offline
NITROUSN  Offline
N
Do yourself a favor and actually test the fuel pressure with a guage. Knowing what the actual pressure reading is the correct way to diagnose the problem. To little pressure as well as to much fuel pressure will both cause a host of problems.
Re: 92 Ram. Im begging for good mechanic advice...please [Re: moparmojo] #139791
10/22/08 10:51 PM
10/22/08 10:51 PM
chicagoland,usa
buildanother Offline
chicagoland,usa
Is that a tbi? I had a 90 tbi equipped ramcharger with a bad sbec (computer) that would die when I hit a nasty bump, took a while to locate that prob. The bummer was, that the computer available at the dealer is only rebuilt and not available new. Still cured the prob. for me.
Re: 92 Ram. Im begging for good mechanic advice...please [Re: NITROUSN] #139792
10/23/08 05:53 AM
10/23/08 05:53 AM
places
79powerwagon Offline
places
Also check your steel fuel line from the tank for rust. You may not see/smell anything, but a tiny pin-hole will defeat your pump. DAMHIK...
Re: 92 Ram. Im begging for good mechanic advice...please [Re: buildanother] #139793
10/23/08 08:25 AM
10/23/08 08:25 AM
Louisville, KY.
Scottmon Offline
Scottmon  Offline
Louisville, KY.
'92 should be the SMPI Magnum motor.
Definitely, check fuel pressure and for any codes.
Page 1 of 3 1 2 3
