Re: Track Day
[Re: edco440]
#1396856
03/04/13 06:00 PM
03/04/13 06:00 PM
Posts: 96,666 On The Boat, On The Lake, Wa. ...
amxautox
Still Retired. Still Posting on Moparts. A Lot.
Yes, BOTH sides.
One rod on the left side of the engine, and one rod on the right side of the engine, AT THE SAME TIME.
Have someone in the driver's seat. Engine running, in gear, parking brake on, his foot HARD on the brakes.
Stand beside the right fender and watch the motormount rubber.
Have the 'driver' punch the throttle.
The rubber will compress and you can see it, expecialy when you have a rod on the left side as the left won't come up hardly, therefore the right HAS to go down and compress the rubber as the engine WILL torque over.
Tom
"Everyone should believe in something; I believe I'll go fishing."
-Henry David Thoreau
Men and fish are alike. They both get into trouble when they open their mouths
author unknown
Re: Track Day
[Re: amxautox]
#1396857
03/04/13 07:01 PM
03/04/13 07:01 PM
Posts: 1,074 Manitoba Canada
67autocross
Manitoba Canada
Why not a engine plate at that point? It would also tie the front frame rails together.
A new iron curtain drawn across the 49th parallel
Re: Track Day
[Re: 67autocross]
#1396858
03/04/13 07:04 PM
03/04/13 07:04 PM
amxautox
Some organizations don't allow plates, or solid mounts.
Tom
author unknown
Re: Track Day
[Re: amxautox]
#1396859
03/04/13 08:45 PM
03/04/13 08:45 PM
Posts: 4,302 Nebraska
72Swinger
Nebraska
I'm gonna go solid driver side ,poly passenger side.
Mopar to the bone!!!
Re: Track Day
[Re: dangina]
#1396862
03/05/13 01:33 PM
03/05/13 01:33 PM
Posts: 4,323 NY NY
340duster340
NY NY
thanks for posting the pics and nice ride. what tires are you running and how many laps do you get out of them?
also does your car have head rests? if not i would seriously recommend getting seats with head rest. talk to any paramedic and ask them what a pez dispenser refers to in their line of work.
1966 Dart GT
...down to only 1 mopar for the first time in 15 years!
Re: Track Day
[Re: amxautox]
#1396865
03/05/13 05:38 PM
03/05/13 05:38 PM
Posts: 223 indy
edco440
indy
Yes, BOTH sides.
Stand beside the right fender and watch the motormount rubber. ! Have the 'driver' punch the throttle.
Thank You,, AMXAUTO Nice brake cooling set-up Tom,, Mitch L. sent me some pics of the Fabbed alloy ones,, very nice. pics on Mopax e-chat Chris Heineys site,,Thanks again Tom!
Re: Track Day
[Re: ThermoQuad]
#1396866
03/05/13 08:43 PM
03/05/13 08:43 PM
Posts: 14 Plainfield, NJ - USA
mustardketchup
Great looking car, HUSTLESTUFF. The car has a great color combo and a great stance. Plus, you get it on the track! Tom Quad, in particular, always preaches the virtues of extra brake cooling. While poking around on V8Miata.net, I came across a brake thread and some posters were also promoting that same philosophy. The guy at V8Miata.net added a twist to this concept by using the electric air injection smog pump on his 2002 LS-1 Camaro to provide continuous airflow to the front brakes. This way, the brakes are being force-fed air if the car is moving slowly or even if it is stopped - and he claims it moves a "truckload" of air. His monetary outlay was less than $50; a few bucks more if you use "proper" brake hose ducting. The poster's build-up of the system was originally posted on LS1Tech.com. Here's that link: http://ls1tech.com/forums/suspension-brakes/1572847-diy-brake-ducts-less-then-20-bucks.htmlI'm also including the V8Miata.net link because a clear picture of the electric smog pump was provided in the post (for those of you who will scour salvage yards): http://www.v8miata.net/suspension-drivetrain-12/what-brake-setup-you-running-791/I hope this is helpful to you people who take your cars out to track events. Lawrence Brady
Re: Track Day
[Re: HUSTLESTUFF]
#1396867
03/05/13 08:46 PM
03/05/13 08:46 PM
Posts: 2,471 Answering the call of the wild
ThermoQuad
Hot brakes are no fun...imagine running 45 minutes a session. I can't imagine running with out a thermostat. We put an external-in front of the core support ps cooler to help take heat out of the engine compartment.
How did you take care of the engine venting?
Here is how you sneak the mounts for the shoulder belts into a charger. Those are the correct eye bolts but what you don't see is the angle iron reinforcement that runs across the inside top of the package tray.
Check out the 3pt seat belt for the kid
Re: Track Day
[Re: RichV]
#1396870
03/06/13 03:40 AM
03/06/13 03:40 AM
Posts: 1,376 NORTHERN CA
HUSTLESTUFF
NORTHERN CA
Ordered up the Schumacher torque straps today. I vented the car w/ -8 fittings in valve covers and hose into frame rails. On my list is a breather tank. I have a 2 row power steering cooler up front.
I have some brake ducting stuff from when I made a spoiler that I didn't like so I may play with that. Hope to do track day next month.
I couldn't get the video to load had some audio problem and it said 1200 min to load. Slow internet out in the country. But big shop!!! Hopefully the instructor will email me the video he had.
Thanks for the nice comments on the car. Mike
"Were in it to win it. Anything less will end up being..... A whole lot of fun doing!!" UNLAWFL RIP UN
Re: Track Day
[Re: BergmanAutoCraft]
#1396872
03/06/13 03:45 PM
03/06/13 03:45 PM
HUSTLESTUFF
NORTHERN CA
I was looking under the car at how the passenger side torque strap would fit...I lost two of the three ARP motor mount bolts. I also lost two of three driver side collector bolts. Lots of stresses.
