I did 4-7 cam change #1396584
03/03/13 12:50 PM
03/03/13 12:50 PM
Salina ks
572_dup2 Offline OP
Back On The Bumper!!
572_dup2  Offline OP
Salina ks
Ive also added 8-o2's an felt doing these 2 things at same time was good idea.
Shawn Jennings
Re: I did 4-7 cam change [Re: 572_dup2] #1396585
03/03/13 12:57 PM
03/03/13 12:57 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
Ive also added 8o2s an felt doing these 2 things at same time was good idea.
1st cam to 2nd cam specs? 8o2? What Compression?
Doug
Re: I did 4-7 cam change [Re: dvw] #1396586
03/03/13 01:13 PM
03/03/13 01:13 PM
acworth / N. georgia - south e...
cheapstreetdustr Offline
are the 8o2s digital..how are you reading 8 ports?
365" Iron J heads,,3480lbs best 1.39 60ft on SS springs.10.54,124 mph ...6.67 1/8th et.average 60fts 1.46 w/ small cam &.063 no2 pill tagged & insured
[image][/image]
Re: I did 4-7 cam change [Re: cheapstreetdustr] #1396587
03/03/13 01:25 PM
03/03/13 01:25 PM
Salina ks
572_dup2 Offline OP
572_dup2  Offline OP
Salina ks
I didn't explain that very good. I have racepak with an o2 sensor in every header tube.
Shawn Jennings
Re: I did 4-7 cam change [Re: 572_dup2] #1396588
03/03/13 01:27 PM
03/03/13 01:27 PM
northern,Ohio,USA
Clanton Offline
Clanton  Offline
northern,Ohio,USA
Interesting!I would like to see the headers if you get the chance.
Re: I did 4-7 cam change [Re: 572_dup2] #1396589
03/03/13 01:31 PM
03/03/13 01:31 PM
tboomer Offline
tboomer  Offline
Nice,Shawn! Gonna run S/G again this year?
Re: I did 4-7 cam change [Re: Clanton] #1396590
03/03/13 01:31 PM
03/03/13 01:31 PM
Salina ks
572_dup2 Offline OP
572_dup2  Offline OP
Salina ks
Shawn Jennings
Re: I did 4-7 cam change [Re: 572_dup2] #1396591
03/03/13 01:40 PM
03/03/13 01:40 PM
Salina ks
572_dup2 Offline OP
572_dup2  Offline OP
Salina ks
Super Comp Ted. Im going to get a round win at National event yet.
Shawn Jennings
Re: I did 4-7 cam change [Re: 572_dup2] #1396592
03/03/13 01:41 PM
03/03/13 01:41 PM
tboomer Offline
tboomer  Offline
Good luck!! Go get those piperacks!!
Re: I did 4-7 cam change [Re: 572_dup2] #1396593
03/03/13 02:05 PM
03/03/13 02:05 PM
San Jose Ca.
boatracer572 Offline
San Jose Ca.
Good move Sean!! you wont regret spending the $$$$
dded 8 o2 sensors a while back.very helpfull with tuning a pair af carbs.
Re: I did 4-7 cam change [Re: 572_dup2] #1396594
03/03/13 02:07 PM
03/03/13 02:07 PM
northern,Ohio,USA
Clanton Offline
Clanton  Offline
northern,Ohio,USA
Thx!
Re: I did 4-7 cam change [Re: 572_dup2] #1396595
03/03/13 02:23 PM
03/03/13 02:23 PM
St. Paul , Mn.
tubtar Offline
tubtar  Offline
St. Paul , Mn.
This picture had me grinning like a kid at Christmas.
Re: I did 4-7 cam change [Re: tubtar] #1396596
03/03/13 02:41 PM
03/03/13 02:41 PM
San Jose Ca.
San Jose Ca.
headers before coating
Re: I did 4-7 cam change [Re: 572_dup2] #1396597
03/03/13 03:29 PM
03/03/13 03:29 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
OK I'm brain dead, that makes sense. Cam Specs?
Re: I did 4-7 cam change [Re: dvw] #1396598
03/03/13 05:27 PM
03/03/13 05:27 PM
cincinnati ohio
mcat4321 Offline
mcat4321  Offline
cincinnati ohio
i have read alot about 4-7 swap...
is it really worth the effort?
some of the BESt engine builders in the country dont seem to think so. no matter the order you have 2 side by side firing. some say it changes the deflection on a weaker crank adding a few ponies , but a good crank, no help.. im interested in what you experience
Re: I did 4-7 cam change [Re: mcat4321] #1396599
03/03/13 06:55 PM
03/03/13 06:55 PM
Utah and Alaska
astjp2 Offline
astjp2  Offline
Utah and Alaska
Its not just he 4-7 you also need the 3-2 swap, if it was not benificial, then there wouldn't be so many nascar teams using it and GM would not have used in in the LS series. I did a lot of research and it has to do with the power pulses in relation to the crank throw position. There are a few articles on this and mostly is had to do with creating a smoother running engine, not really for much more power. Tim
1941 Taylorcraft
1968 Charger
1994 Wrangler
1998 Wrangler
2008 Kia Rio
2017 Jetta
Re: I did 4-7 cam change [Re: mcat4321] #1396600
03/04/13 04:32 AM
03/04/13 04:32 AM
Park Forest, IL
slantzilla Offline
slantzilla  Offline
Park Forest, IL
Thing I've seen discussed most is it makes rod bearings last longer.
Re: I did 4-7 cam change [Re: slantzilla] #1396601
03/04/13 06:00 AM
03/04/13 06:00 AM
IL. Jerseyville
jg309 Offline
jg309  Offline
IL. Jerseyville
the 4 cyl. swap removes the harmoics & my engine runs a lott easer, got different sound aswell
Re: I did 4-7 cam change [Re: 572_dup2] #1396602
03/04/13 02:30 PM
03/04/13 02:30 PM
Penna
70satelliteguy Offline
Penna
Shawn,off topic just a little but what size headers are those? Also, on the photo with your post I like the way those Good years look during a wheel stand. Not all bundled up or distorted for a car of your weight. What size are those and what pressure are you running in those? I have problems wearing out my sidewalls on my Good Years(31/14.0's)and only working well for 20-30 passes or so.
Thanks MIke
Re: I did 4-7 cam change [Re: 70satelliteguy] #1396603
03/04/13 03:27 PM
03/04/13 03:27 PM
Salina ks
572_dup2 Offline OP
572_dup2  Offline OP
Salina ks
2 1/4 - 2 3/8. An friend an i made those 11yrs. 14x32 Goodyear pressure was 10.5
Shawn Jennings
