Re: Spring Fling/Willow Springs Open track tech inspection?
[Re: migsBIG]
#1396417
03/21/13 01:46 PM
03/21/13 01:46 PM
Posts: 339 Gilroy,CA.
mopardude318
Gilroy,CA.
I would love to attend this. Only problem is my car has failed on me 2 years in a row right into the trip to spring fling! . I really want to attend this event and enter my yellow turd of a barracuda for some fun. Gonna see what I can do in the next 6 weeks to get it ready in time. Really want to try this, much more fun that driving the congested freeways around here.
Hey Mig, if ya need an extra hand with something on your car, hand ya tools, hold up a tranny, fab fuel lines, or whatever else, let me know. I'm only a phone call away. Id' like to see your car out there. I'd drive my cuda out there, but 6 hours one way in that thing is alotta gas money!
408 Stroker 533 HP 520 FT LBS...........................1970 Dart RMS AlterKation
[Re: migsBIG]
#1396420
03/24/13 10:37 PM
03/24/13 10:37 PM
Posts: 27,483 So Cal
autoxcuda
So Cal
...thinking of swapping in that 360 crate motor and running that. Wondering if the new TTI shorty headers will work with that and some dart ratio arm.
TTI shorties will work with Firm Feel long fast ratio arms. Big and small block.
I have a bunch of pictures I took of the small block versions. I'll post later in that thread.
[Re: autoxcuda]
#1396421
04/29/13 02:19 PM
04/29/13 02:19 PM
autoxcuda
So Cal
Only two weeks away... Thursday – May 9, 2013 Spring Fling Speed Festival Willow Springs Raceway Rosamond, California 7:00 am Drivers meeting 8:00 am Course open to the first group 8:00 am New Driver instruction class and ride along instruction 12:00 pm Free cruise laps for spectators $10 per person to spectate 5:00 pm Track Closed 6:30 pm Dinner ![](https://board.moparts.org/ubbthreads/upload2/7686963-SteveSFSF10Sm14.JPG)
[Re: 72440CUDA]
#1396424
05/03/13 12:42 PM
05/03/13 12:42 PM
autoxcuda
So Cal
I'll be there for the parade laps, first time out. I just ordered new wheels and tires and I don't think I'll get them in time. So I'm stuck with my 12 year old BFG T/A's and I wouldn't feel safe out there ![](/ubbthreads/images/graemlins/crazy.gif)
Next year if I get my brakes upgraded, I'm definately in it for all day
Don't sweat it to start with.
I'll be running on my 13 year old BFG's and stock type disks and drum rear. You gotta jump on the learning curve sometime.
Herb's 68 black Hemi GTX had 11" willwood smaller type drag brakes. He ran all day. We pick the larger track at Willow Springs becasuse it's not a demanding on brakes as the smaller track or Buttonwillow.
[Re: autoxcuda]
#1396425
05/03/13 03:31 PM
05/03/13 03:31 PM
Posts: 1,442 NW Chicago suburban area
Mopar Mitch
Regarding the age and reliability of those old BFG tires (T/A Radials?), I've beed driving on mine for the past 4-5 years on the street and some local hi-speed road course lapping events. Size 245-60-15 front, 275-60-15 rear... bought them ~1990 and basically they sat in my garage unused until about 2009 (I got real serious and began trailering the car full-time on autocross race rubber)... currently remounted onto 15x8 vintage minilite rims (were originally mounted on 15x7 rally rims). I know they're old and have hardened some, but actually they drive locally a-ok, fine on the highway, and ok on the road course events (avrg speed bewteen 70-80, hitting 110 max on some straights.. I drive it easy on those road courses as its just for social fun... bump the tires up to ~36 front, 34 rear psi.. could go a little more. So, I've now got about 2500 miles on my ~22 year old new tires. I plan to replace them with 255-60-15 fronts and again 275-60-15 rears BFG Radial T/As... they are an ok tire just for cruising and give semi-reasonable performance. For pylon autocross competition events, I run Hossier A6 275-45-16 DOT race radials on my 16x10 road race Centerline forged aluminum lightweight rims.. and I see some of the serious hi-speed road course "competition solo" cars running the Hossier A6 tires also.. they are very sticky when hot! I intend (dreaming again) to eventually get some 17 or 18 rims (9 min, maybe 10-11 widths) with hi-speed soft compound tires (~100-200 tread wear) and use them more safely and with higher confidence on the hi-speed road courses... and likely drive to/from those specific events on those same tires. All it takes is $$. Those 12 yrold BFGs of your's will get you to/from the event and.. just don't push it real hard.. and increase the psi about 5 pounds (maybe a little more) than what you normally drive on them.. just for the road course event.
Mopar Mitch
"Road racers and autocrossers go in deeper and come out harder!"... and rain never stops us from having fun with our cars... in fact, it makes us better drivers!
Check out MOPAR ACTION MAGAZINE, August 2006 issue for feature article and specs on my autocross T/A!
[Re: autoxcuda]
#1396427
05/04/13 01:34 PM
05/04/13 01:34 PM
Mopar Mitch
Those videos are so cooll! How did you mount the camera so it didn't fall off???? Did you use a GoPro camera?
Mopar Mitch
[Re: autoxcuda]
#1396429
05/05/13 10:48 AM
05/05/13 10:48 AM
Posts: 3,289 West Coast, USA
jbc426
West Coast, USA
I attended for the first time last year in my slant six powered 1968 Barracuda convertible. I have the suspension upgraded with stiffer springs, a pair of swaybars and some Koni shocks. I also have some older BFG Radial TA's.
This year the car has more power with the EFI 5.9 Magnum/727 & 3.23 Suregrip swap I did over the winter. I can already tell the car has a bit more oversteer due to the added weight (+-75lbs) in the front end, so it will be even more exciting. More power and suregrip on a road course, dang I love Mopars!
Willow Springs is a big track. Last year, towards the middle of the day with the /6 & 2.93 rear end gears, I was able to build up to 98 mph entering the back sweeper. It was exciting, I progressed at my own pace and I definitely benefitted from the new driver meeting at the beginning of the day.
There were several guys who literally melted their tires down to the cords, because they pushed their cars so hard. My old TA's did get some wear that day, but it was minimal. I still have them on the car for this year.
My point is that you have all day to get comfortable with your car and the track. The key is to start off slow, build up as you gain experience throughout the day and leave yourself a comfortable but exciting margin of safety.
It was one of the funnest things I've done all year, and I can hardly wait until this Thursday.
[Re: 72440CUDA]
#1396431
05/10/13 05:31 AM
05/10/13 05:31 AM
autoxcuda
So Cal
Bah, my tow vehicle lost two tires on the way out... Didn't get there until about 3:30, coming from Vegas. I missed out. Walked around with my wife and 3yr old daughter for a few minutes then left for Van Nuys. Lesson learned, leave the day before and spend the night.
Things were winding down. I was there. Bummer would loved to have hooked up. Probably could have got you in on a ride along. Bummer. I was looking for a yellow cuda.
