need more power from 273 #1396365
03/03/13 01:10 AM
03/03/13 01:10 AM
shavertown pa.
K
kbeeper69 Offline OP
K
shavertown pa.
Is it even worth trying to add more power to this engine. 1968 satellite just looking for a little more oomph.
Re: need more power from 273 [Re: kbeeper69] #1396366
03/03/13 01:20 AM
03/03/13 01:20 AM
bean town ....Ca
W
WHITEDART Offline
WHITEDART  Offline
W
bean town ....Ca
theres always a little in every thing. but a 360 is the easy way and a good plat form to grow from
In the 8s N/A.with Brett miller W8's
5.07 at 133 at 2700lb
Re: need more power from 273 [Re: WHITEDART] #1396367
03/03/13 04:49 AM
03/03/13 04:49 AM
Sydney NSW
Rodsports Offline
Rodsports  Offline
Sydney NSW
Just the cost mate, I found it cheaper to rebuild a 318 as the pistons for the 273 were ridiculously expensive.
Re: need more power from 273 [Re: Rodsports] #1396368
03/03/13 09:48 AM
03/03/13 09:48 AM
Holly/MI
Dean_Kuzluzski Offline
Holly/MI
Great point, but is the OP just trying to upgrade an already healthy longblock or a total rebuild?
The factory 340 replacement cam, a Edelbrock performer or LD4B, small 4 barrer (500-625), cheap headers and a snappy ignition curve would work wonders if that's what he's asking. Maybe even some port match and bowl porting if you wanna go crazy.
Re: need more power from 273 [Re: kbeeper69] #1396369
03/03/13 09:56 AM
03/03/13 09:56 AM
Owego, NY
JBurch Offline
JBurch  Offline
Owego, NY
Turbo, or supercharge........
Re: need more power from 273 [Re: JBurch] #1396370
03/03/13 10:04 AM
03/03/13 10:04 AM
Lynchburg, VA
Leon441 Offline
Leon441  Offline
Lynchburg, VA
I played with these engines year ago. Not much gain for the buck at all.
A 360 low compression with a 4 barrel will be the cheapest.
Re: need more power from 273 [Re: Leon441] #1396371
03/03/13 11:13 AM
03/03/13 11:13 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
I bought this 273 four barrel 235 hp 66 Dart in 1974. I rebuilt the 273 and added a bigger solid cam. I think it had the original AFB on it that I used and I think I used an Eddy 318 dual plane intake. I added JR fenderwell headers. It was a four speed and I put a drum to drum rear in it from a 68 Dart 340 car. Had 3.91's and ran high 14's. But when I wanted to get serious I was going to notch the cyl and add 340 heads. I ended up dropping a 340 in it with 4.56's and it ran a best of 11.90's until I rolled it in 1982. It just seemed everytime I really wanted to step up some I kept going to 340 or 360 parts so thats why I just put a 340 in it. I would say the headers and 318 Eddy intake helped my 10.5 to 1 comp 235hp 273 some for a few simple bolt ons. It just seemed everytime I wanted to try and make some real hp I kept hearing about adding 340 parts so thats why I finally put one in it. You have to do some serious head work to really start getting some power out of the 273. Good luck which ever way you go. Ron
Re: need more power from 273 [Re: 383man] #1396372
03/03/13 11:36 AM
03/03/13 11:36 AM
People's Republic of Mass.
Belvedere2 Offline
Belvedere2  Offline
That was one nice car!
Re: need more power from 273 [Re: kbeeper69] #1396373
03/03/13 11:38 AM
03/03/13 11:38 AM
gregsdart Offline
gregsdart  Offline
If you look at the class records for the 273 stockers, compared to a 318, 360 or 340 that will give you an idea of what a difference there will be between the sizes of motors. Cubic inches x airflow x good combo x rpm = horsepower. Your 273 is hampered with a 3.31 stroke and small bore, and in need of a solid cam and better valve train,rods and pistons to build a lot of hp. It can however respond to basic stuff like headers, manifold, cam etc. Just remember you still only have 273 cubes.
There is some fun in taking the road less traveled, so you might find it a lot of fun to develop a package that will run hard with a small motor. That of course would be easier with a four speed than an auto trans.
Re: need more power from 273 [Re: kbeeper69] #1396374
03/03/13 11:47 AM
03/03/13 11:47 AM
Central New York
slippery440 Offline
Crybaby440
slippery440  Offline
Crybaby440
Central New York
Easy way I found was to put a 340 or 360 in and tell everyone that it is a 273. Just like the chevy 265/283/302/327 all outdated and exspensive if you do want to rebuild.
If the MODS did their job I would not be hitting the notify MOD button. LOL
Re: need more power from 273 [Re: slippery440] #1396375
03/03/13 04:31 PM
03/03/13 04:31 PM
shavertown pa.
K
K
shavertown pa.
66 thousand mile original motor .only 2 barrel. Just looking for a few options.my first small block car.
Re: need more power from 273 [Re: kbeeper69] #1396376
03/03/13 05:01 PM
03/03/13 05:01 PM
Canada
WO23Coronet Offline
WO23Coronet  Offline
Canada
Since it sounds like its in good shape and doesn't need a rebuild, AND it sounds like its mainly going to be a cruiser, I would do what was previously recommended and put an Edelbrock performer on it (has the the smaller ports), 4bbl, and headers/dual exhaust. If u want anymore than that ie changing heads, cam, etc, just get a 360 (or 5.9 Magnum).
Re: need more power from 273 [Re: WO23Coronet] #1396377
03/03/13 07:32 PM
03/03/13 07:32 PM
Lynchburg, VA
Leon441 Offline
Leon441  Offline
Lynchburg, VA
What year is the 273? Everyone I ever had was solid lift from the factory. You cannot bolt a 318-360 intake on it unless it is 66 or newer engine.
The engines can get good fuel mileage though.
Re: need more power from 273 [Re: Leon441] #1396378
03/03/13 11:24 PM
03/03/13 11:24 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
68-69 all had hydraulic cams
Re: need more power from 273 [Re: Belvedere2] #1396379
03/04/13 01:12 AM
03/04/13 01:12 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
Thank you. Ron
Re: need more power from 273 [Re: 383man] #1396380
03/04/13 12:58 PM
03/04/13 12:58 PM
NC
SLOW67 Offline
SLOW67  Offline
NC
I had a 273 in my car until I went with the 318 and turbo. A single plane intake with a 400cfm AVS and a set of headers made mine alittle more lively. The only thing that really woke it up was a small converter and the 5.38 gear I had in it for a couple months lol
Re: need more power from 273 [Re: SLOW67] #1396381
03/04/13 02:23 PM
03/04/13 02:23 PM
Puyallup, WA
StealthWedge67 Offline
Puyallup, WA
If it were in an A-body, I'd say do the standard hot-rod stuff (intake, carb, headers, etc.). But in a car that likely is pushing 3800 lbs, 273 cubes comes with a reality thats going to be a losing battle. Personally, I'd spend any money slowly on getting a 360 together.
Re: need more power from 273 [Re: StealthWedge67] #1396382
03/05/13 04:22 PM
03/05/13 04:22 PM
Grand Haven, MI
patrick Offline
patrick  Offline
Grand Haven, MI
I'd be watching craigslist for a running magnum 360, swap the t-chain cover, get a car oil pan, an eddie magnum air gap, and a 600-650cfmish carb
2017 Grand Cherokee Overland
Re: need more power from 273 [Re: kbeeper69] #1396383
03/06/13 09:17 AM
03/06/13 09:17 AM
the frozen wastes...
Pale_Roader Offline
Swears too much
Pale_Roader  Offline
Swears too much
It can still be a good little driver that sounds cool... to some thats all you need in a car. A 273 in a B-body will never be fast... not without a ridiculous effort and outlay anyways. Keep in mind the 273 is almost 100cid smaller than the 360.
Quick fun? Headers, 2.5" dual exhaust, pick your favorite sounding mufflers. Aluminum dual-plane 4bbl intake, carb, open-element air cleaner. Electronic ignition maybe? for a bit better driver, though it wont make you any faster. Tune it very well, recurve the distributor, etc. Pull the AC compressor off if it has one. Lose any weight in the car you dont need.
Spending a bit more money? Find a Magnum 5.2 or 5.9L top-end... heads, all that goes with, and buy an RPM intake. This will be an improvement that you can actually feel, and make it more efficient too. Gears for the rear... what you have is probably a bit long. A cam will help wake that lil' thing up too, especially with the heads if you go that route.
Even more money? swap in a 340 or 360, or better yet, a 360 Magnum or big block. This really is the first real step up to any real speed and doesn't have to cost all that much.
Re: need more power from 273 [Re: Pale_Roader] #1396384
03/06/13 11:11 AM
03/06/13 11:11 AM
Grand Haven, MI
patrick Offline
patrick  Offline
Grand Haven, MI
magnum valves are too big for a stock 273 without notching the bore....
I'd probably limit it to a dual exhaust system, intake and 4bbl, parts that can be easily swapped to a larger engine. anything more than that, you're better off starting off with a 318 or 360...
