Guys,
I am almost ready to put the window regulators and new glass back into my doors and I was wondering the proper order (or any tips) on how to reassemble this with minimal effort. Most of all I am scared to scratch up the new glass....
I have all the "guts" of both doors out and cleaned up. I have the glasses from AMD as well. The only parts inside the door now are the latch assembly/rods/lock/handles. I am guessing maybe reinstall the rest in this order?
1. Put in the regulator piece by piece and then assemble inside the door through the holes and loosely bolt into place.
2. Install the clips and moldings/felt fuzzies on the top of the door
3. Slide the glass in and fasten to the reg with the four screws
Am I getting this right? I had to remove the glass first to get the reg out which also had to come apart so I could rotate the crank mechanism to get it out. I am thinking I will have to install the molding and new felts first as the glass will black them once installed.
Car is a 1973 Charger.
Please let me know if I am going in the right direction here or if I forgot anything. Any tips or experiences are appreciated!
