Aftermarket exhaust..2001 CTD #1396061
03/02/13 04:14 PM
03/02/13 04:14 PM
NJ-USA
HPMike Offline OP
HPMike  Offline OP
NJ-USA
Whats the best option for these? I have installed many different ones on customers vehicles. The 4" is what I am looking for. The options are just dizzying... Which are you running and why?..
Thanks..
MB
Re: Aftermarket exhaust..2001 CTD [Re: HPMike] #1396062
03/02/13 07:40 PM
03/02/13 07:40 PM
Missouri U.S.A.
71yelladustr Offline
Missouri U.S.A.
I have run both MBRP and Diamond Eye 4 inch aluminized exhaust systems (sans muffler)on my previous trucks without any issues. Both fit and function well without a lot of drone in the cab.
392 gen III hemi on E-85 727 trans Dana 60
10.02@134
Re: Aftermarket exhaust..2001 CTD [Re: 71yelladustr] #1396063
03/02/13 10:31 PM
03/02/13 10:31 PM
NJ-USA
HPMike Offline OP
HPMike  Offline OP
NJ-USA
Thanks..
Do they come with a polished exhaust tip?
MB
Re: Aftermarket exhaust..2001 CTD [Re: HPMike] #1396064
03/02/13 11:04 PM
03/02/13 11:04 PM
Chilliwack B.C. Canada
RUNCHARGER Offline
RUNCHARGER  Offline
I just installed a Dynomax 4" cat back on my 05 today. Took about 10 minutes once I had the old stuff cut off. Pretty much sounds stock though.
Sheldon
Re: Aftermarket exhaust..2001 CTD [Re: RUNCHARGER] #1396065
03/03/13 12:13 AM
03/03/13 12:13 AM
Missouri U.S.A.
Missouri U.S.A.
You can get them with a polished tip.
10.02@134
Re: Aftermarket exhaust..2001 CTD [Re: 71yelladustr] #1396066
03/03/13 12:51 AM
03/03/13 12:51 AM
Lehigh Acres, Florida
rickstershemi Offline
MBRP and don't look back
Rickster
Re: Aftermarket exhaust..2001 CTD [Re: rickstershemi] #1396067
03/03/13 01:32 AM
03/03/13 01:32 AM
Mission BC
10sec440 Offline
10sec440  Offline
Mission BC
I just put a Diamond Eye 4" stainless system on my truck today. Top notch, and affordable.
Re: Aftermarket exhaust..2001 CTD [Re: rickstershemi] #1396068
03/03/13 04:08 PM
03/03/13 04:08 PM
Q
qkRick Offline
qkRick  Offline
Q
Rickster
Re: Aftermarket exhaust..2001 CTD [Re: qkRick] #1396069
03/03/13 10:17 PM
03/03/13 10:17 PM
Alexandria,La.
BigTerry Offline
BigTerry  Offline
Alexandria,La.
Rickster
wow!! that system sound great!!
Re: Aftermarket exhaust..2001 CTD [Re: BigTerry] #1396070
03/03/13 11:11 PM
03/03/13 11:11 PM
San Francisco Ca
SCATPK Offline
SCATPK  Offline
San Francisco Ca
I still have the stock factory exhaust on my 98.5 24 valve. I like the way it sounds and have thought about changing it out but have wondered if I really will see a performance improvment other than exhaust note? Have you guys noticed any difference in performance with the bigger exhaust systems on your diesels?
Re: Aftermarket exhaust..2001 CTD [Re: SCATPK] #1396071
03/03/13 11:32 PM
03/03/13 11:32 PM
Missouri U.S.A.
Missouri U.S.A.
There is little to be had as far a performance goes until you get some serious fuel added and a larger turbo with a 4 inch outlet. The factory turbo is the bottleneck.
10.02@134
Re: Aftermarket exhaust..2001 CTD [Re: rickstershemi] #1396072
03/03/13 11:53 PM
03/03/13 11:53 PM
Alexandria,La.
BigTerry Offline
BigTerry  Offline
Alexandria,La.
Rickster
is that what you have on your truck?
Re: Aftermarket exhaust..2001 CTD [Re: BigTerry] #1396073
03/04/13 12:57 AM
03/04/13 12:57 AM
The Wet Coast, Canada
megajoltman Offline
megajoltman  Offline
SS Diamond eye 4 inch here, easy install and reasonably priced.
1969 Dart 383/727/D60
CTD Ram 4x4 Mega Cab
Procharged 350Z
Re: Aftermarket exhaust..2001 CTD [Re: BigTerry] #1396074
03/04/13 05:56 PM
03/04/13 05:56 PM
Rickster
Why yes it is.....4" w/6# Extentions (Duals) on my 07 3500 4x4 GMC Duramax/Allison Dually (5 years - looks new)
Rickster
Re: Aftermarket exhaust..2001 CTD [Re: rickstershemi] #1396075
03/04/13 07:14 PM
03/04/13 07:14 PM
Rust Belt, SW PA
Silver70 Offline
Silver70  Offline
Rust Belt, SW PA
I run a 4" mbrp on my 01. Couldn't beat the price, got it from jegs because I needed it quick... but some ebay sellers are cheaper. It's about 16 months old, 2 winters and drove pretty much daily. Exhaust almost looks as good as new still.
Re: Aftermarket exhaust..2001 CTD [Re: SCATPK] #1396076
03/04/13 08:37 PM
03/04/13 08:37 PM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
With no other mods, it will just be for sound.
Re: Aftermarket exhaust..2001 CTD [Re: HPMike] #1396077
03/06/13 07:28 AM
03/06/13 07:28 AM
upstate western ny
sogtx Offline
sogtx  Offline
upstate western ny
Thanks..
MB
d0 NoT buy a magnaflow whatever you do !
Re: Aftermarket exhaust..2001 CTD [Re: DaytonaTurbo] #1396078
03/06/13 05:21 PM
03/06/13 05:21 PM
an8sec70cuda Online content
an8sec70cuda  Online Content
And cooler EGT's. I have the 4" MBRP straight pipe kit on my '01 and love it. Cheap ($260 or so) and easy to install.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Aftermarket exhaust..2001 CTD [Re: an8sec70cuda] #1396079
03/15/13 03:04 AM
03/15/13 03:04 AM
Chicago, IL
moe318 Offline
moe318  Offline
Chicago, IL
Just lost the tail pipe on my 99 eclb 24v stock engine and turbo,not planning on modifying it.Planning on getting the MPRB 4 inch from turbo back kit without muffler.I understand lower egt's ,but will I lose low end torque? What about drone?And the common price at jeg's and summit is 379.99.Any places cheaper? Thanks
Re: Aftermarket exhaust..2001 CTD [Re: moe318] #1396080
03/15/13 07:31 AM
03/15/13 07:31 AM
Coeur d Alene, Idaho
jimbob101 Offline
jimbob101  Offline
Installed a Diamond eye 4" with muffler on a 2000 CTD, aluminized, was $250 shipped to your door, installed and sounds great to me!
-J
