Converting E-body from AC to non-AC #1396046
03/02/13 03:35 PM
03/02/13 03:35 PM
central CT
cudazappa Offline OP
central CT
I bought my Challenger it had non working AC & Heat.
I'd really just rather have working heat.
Aside from removing the underhood stuff, what needs to be done under the dash? Where do I source this stuff?
Also, the Heater control valve is leaking. But it appears this is an A/C only item? I've looked through the FSM, it appears that non-AC e-bodies don't have this?
Thanks for any and all help.
1971 Challenger
Re: Converting E-body from AC to non-AC [Re: cudazappa] #1396047
03/02/13 03:37 PM
03/02/13 03:37 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
The firewall is different....
Re: Converting E-body from AC to non-AC [Re: 1_WILD_RT] #1396048
03/02/13 07:38 PM
03/02/13 07:38 PM
connecticut
pnypwr Offline
pnypwr  Offline
connecticut
so is the lower cowl, dashpad, heater control, heaterbox,...
"Are you gonna bark all day lil doggy? Or are you gonna bite?"
05 ram 2500 ctd
74 gremlin x 360
65 mustang 347
70 coronet R/T 440
03 Mach 1
Re: Converting E-body from AC to non-AC [Re: pnypwr] #1396049
03/03/13 06:20 PM
03/03/13 06:20 PM
Harrisburg, Pa.
screamindriver Offline
Harrisburg, Pa.
You'd have way more work converting over than you'd think...You're better off just buying an aftermarket heater control valve and just let the a/c stuff there...There's a bunch of aftermarket valves that are much cheaper than the NOS bakelite units out there...They don't look the same but work just fine...
So all you really need for heat would be the valve,check the cable from the dash switch to that valve for smooth operation.. Then check that you have a non-leaking vacuum system to operate the plenum doors...
Re: Converting E-body from AC to non-AC [Re: screamindriver] #1396050
03/04/13 04:56 PM
03/04/13 04:56 PM
central CT
central CT
Thanks, I think that's exactly what I'll do.... for now.
1971 Challenger
