Page 1 of 3 1 2 3
15x7 steel wheels #1395415
03/01/13 03:55 AM
03/01/13 03:55 AM
Maple Valley, WA
70mopes Offline OP
70mopes  Offline OP
Maple Valley, WA
Who sells a good reproduction 15x7 wheel that is somewhat similar in overall appearance to the 450 wheel?
Re: 15x7 steel wheels [Re: 70mopes] #1395416
03/01/13 07:35 AM
03/01/13 07:35 AM
S.I. N.Y.
1MYTGTX Offline
1MYTGTX  Offline
S.I. N.Y.
I got mine from Summit Racing....Wheel Vintiques makes them
1MYTGTX
Re: 15x7 steel wheels [Re: 1MYTGTX] #1395417
03/01/13 12:10 PM
03/01/13 12:10 PM
Kelowna, B.C. Canada
DPelletier Offline
DPelletier  Offline
so did I and all I can say is check the wheels for roundness and runout BEFORE painting them and mounting your tires, etc. Mine were bad enough that one couldn't even be balanced properly.
1970 Super Bee 440 Six Pack 1974 'Cuda 2008 Ram 3500 Diesel 2006 Ram 3500 Diesel 2004.5 Ram 2500 Diesel 2003 Ram 3500 Diesel 2006 Durango Limited [url] http://1970superbee.piczo.com [/url]
Re: 15x7 steel wheels [Re: 1MYTGTX] #1395418
03/01/13 12:57 PM
03/01/13 12:57 PM
Sac, CA
mopowers Offline
mopowers  Offline
Sac, CA
What kind of finish do they come with? How did you prep it for paint?
That wheel looks absolutely flawless!! Nice work!
Re: 15x7 steel wheels [Re: DPelletier] #1395419
03/01/13 12:59 PM
03/01/13 12:59 PM
Sac, CA
mopowers Offline
mopowers  Offline
Sac, CA
Is there an easy "at-home" way of checking for roundness and run out? Will mounting them on an axle and spinning it with a dial indicator riding on the rim work? I guess you'd having to do it both horizontally and vertically? How much run-out and "out of roundness" is acceptable?
Re: 15x7 steel wheels [Re: mopowers] #1395420
03/01/13 01:47 PM
03/01/13 01:47 PM
RSNOMO Offline
Moparts Torchbearer
RSNOMO  Offline
Moparts Torchbearer
Take 'em to a tire shop and have 'em spin 'em...
Re: 15x7 steel wheels [Re: RSNOMO] #1395421
03/01/13 02:38 PM
03/01/13 02:38 PM
DPelletier Offline
DPelletier  Offline
In theory you could mount them on an axle and make the measurements yourself, but that requires special tools and very carefull measurements...I would just take them to the tire shop
Re: 15x7 steel wheels [Re: DPelletier] #1395422
03/01/13 02:45 PM
03/01/13 02:45 PM
Sac, CA
mopowers Offline
mopowers  Offline
Sac, CA
Is there a tolerance that they should fall under?
Re: 15x7 steel wheels [Re: mopowers] #1395423
03/01/13 02:50 PM
03/01/13 02:50 PM
Wisconsin
Stewpar Offline
Happy Birthday Stewpar  Offline
Wisconsin
Member "Drdiff" can make them for you as well. He takes original rims and converts them to the smaller center 450 style wheels.
Admiration For Multiple Carburetor Vehicles...
Re: 15x7 steel wheels [Re: DPelletier] #1395424
03/01/13 07:52 PM
03/01/13 07:52 PM
S.I. N.Y.
1MYTGTX Offline
1MYTGTX  Offline
S.I. N.Y.
I brought mine to the tire shop & spun them on a machine after Daves suggestion & warning.
The wheels come painted black. I had a good friend paint them for me ... Thanks Bill!
Just scuffed them up real well & shot them with single stage urethane
1MYTGTX
Re: 15x7 steel wheels [Re: 1MYTGTX] #1395425
03/01/13 10:18 PM
03/01/13 10:18 PM
Tennessee
Hemi ragtop Offline
Hemi ragtop  Offline
Tennessee
I bought mine from some East Tn. boys, pulled them out of the woods and took them home and painted them, $25 ea? they balanced out fine.
Re: 15x7 steel wheels [Re: 70mopes] #1395426
03/02/13 12:13 AM
03/02/13 12:13 AM
Chilliwack B.C. Canada
RUNCHARGER Offline
RUNCHARGER  Offline
None of these look like 450's though.
Sheldon
Re: 15x7 steel wheels [Re: RUNCHARGER] #1395427
03/02/13 10:56 AM
03/02/13 10:56 AM
Wisconsin
Stewpar Offline
Wisconsin
Sheldon
Exactly...........
Re: 15x7 steel wheels [Re: Stewpar] #1395428
03/03/13 06:52 PM
03/03/13 06:52 PM
Highland, MI.
Sunroofcuda Offline
Sunroofcuda  Offline
Highland, MI.
That's why 450's bring BIG bucks! Also, Wheel Vintiques does not "make" steelies. NOBODY reproduces these wheels - Rallyes & Magnums yes, steelies no. WV removes original centers out of used wheels & welds them into new outer rings that I believe they actually produce. There is no other known source for the rings.
OK, let's hear all the "I know where there's a set on a car in a junkyard for $5.00 each" stories!
Re: 15x7 steel wheels [Re: RUNCHARGER] #1395429
03/05/13 02:37 PM
03/05/13 02:37 PM
Manhattan, IL
SixPackRT Offline
SixPackRT  Offline
Manhattan, IL
Sheldon
As far as I know there is nothing on the market new that looks like 450 wheels. Been down that road not too long ago. Your only options for something that looks the part are either buy the real thing $$$$$ (or the 71 version $$$$$$ too), or have them made. I took centers from 70 14" rims (common) and put them in Olds 15 x 7 outers after cutting the olds centers out. That is the only way I know of to make them appear correct and not spend the $$$$ on the real thing. I believe you can use Olds Rallys, some Buick Rallys, or some AMC rims. They are the only ones that have the correct drop down to accept the 14" center and appear correct. I have the advantage of owning a machine shop so it was a no brainer for me. I would do a search here as there are others that have been down this road.
Scott
70 Coronet RT 440+6
64 Dodge 330 - Future Hemi Clone
17 Challenger Hellcat - Green Go Driver
86 Buick T-Type Turbo V-6
Re: 15x7 steel wheels [Re: SixPackRT] #1395430
03/05/13 03:39 PM
03/05/13 03:39 PM
NJ-USA
HPMike Offline
HPMike  Offline
NJ-USA
Sheldon
Scott
If you are patient, you can find some that arent crazy. IT took several years, but I have "only" 1100 in the set of these for my Challenger.....It does take time. Some people still dont know...My buddy just sold one for 100. And he is pretty experienced..I was shocked. I would have bought it for that much..
Re: 15x7 steel wheels [Re: HPMike] #1395431
03/05/13 06:29 PM
03/05/13 06:29 PM
Maple Valley, WA
70mopes Offline OP
70mopes  Offline OP
Maple Valley, WA
Great comments. Thanks to all. I am on the path to have some made as I agree that repros just don't stack up in overall appearance. Now it becomes a matter of finding the donor stuff necessary to create the set I am trying to have made!
Re: 15x7 steel wheels [Re: HPMike] #1395432
03/05/13 06:44 PM
03/05/13 06:44 PM
Midwestern Indiana
duster2 Offline
duster2  Offline
Midwestern Indiana
Wheels I had made a few years ago , but they will not make them now. They refuse to do " cut outs ", probably for insurance and liability reasons.
Frank
Re: 15x7 steel wheels [Re: duster2] #1395433
03/05/13 06:46 PM
03/05/13 06:46 PM
Midwestern Indiana
duster2 Offline
duster2  Offline
Midwestern Indiana
Another from the side , yea I know , the drop is different from the orginal wheels....
Frank
Re: 15x7 steel wheels [Re: HPMike] #1395434
03/05/13 08:25 PM
03/05/13 08:25 PM
S.I. N.Y.
1MYTGTX Offline
1MYTGTX  Offline
S.I. N.Y.
Great pic Mike!
1MYTGTX
Page 1 of 3 1 2 3
