Which vender has the best deal on B1 gaskets #1395397
03/01/13 03:26 AM
03/01/13 03:26 AM
Alabama
Mopar-Al Offline OP
Mopar-Al  Offline OP
Alabama
I have a hard enough time just searching fo any types of deals on B1 related stuff. Not the B1BS stuff, the original head stuff.I find myself needing spares here lately, and am always having to order from koffell's while not so bad, I am just wondering if I can find better prices, thickness sizes, and bulk rates.
I am also trying to find one of the old weld up tunnel ram kits somewhere.
Re: Which vender has the best deal on B1 gaskets [Re: Mopar-Al] #1395398
03/01/13 11:43 AM
03/01/13 11:43 AM
SouthEast Michigan
P
PETE@BESTMACHINE Offline
P
SouthEast Michigan
Fel pro makes intake gaskets #1276 Cometic Head gaskets can be ordered in different Bore sizes and thickness. Hope this helps
Re: Which vender has the best deal on B1 gaskets [Re: PETE@BESTMACHINE] #1395399
03/01/13 12:52 PM
03/01/13 12:52 PM
Alabama
Mopar-Al Offline OP
Mopar-Al  Offline OP
Alabama
Thanks, I do get my cometic gaskets local, so no real problems there, I did need that intake gasket number to, but what number and brand name for the thin valve cover gaskets? I find I need these quite often. I hate using the thin vc gaskets over one time. The heads hold so much oil in the top end, I like to install new one every time ands I am constantly checking under the covers
Re: Which vender has the best deal on B1 gaskets [Re: Mopar-Al] #1395400
03/01/13 01:52 PM
03/01/13 01:52 PM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
Valve cover SCE 264077
http://www.summitracing.com/search?keyword=SCE%20264077&dds=1
Intake manifold SCE 164104
http://www.summitracing.com/parts/sce-164104
Long wait time so order early.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Which vender has the best deal on B1 gaskets [Re: Mopar-Al] #1395401
03/01/13 02:49 PM
03/01/13 02:49 PM
Akron, Ohio U.S.A.
roadhazard Offline
roadhazard  Offline
Akron, Ohio U.S.A.
I offer a thin reusable valve cover gasket for the B-1
No need to replace them after every valve cover removal. Many racers have been running years with the same gaskets.
For a complete listing click the link in my sig line
Re: Which vender has the best deal on B1 gaskets [Re: Mopar-Al] #1395402
03/01/13 03:29 PM
03/01/13 03:29 PM
Finland
LUMI Offline
LUMI  Offline
Finland
but where to find header gaskets?
i have been looking for them a long time
and yes i want use them on a full street car
only place i find them is TTI
is there anotherone source, maybe copper ones, or do i have to make them myself?
Re: Which vender has the best deal on B1 gaskets [Re: roadhazard] #1395403
03/01/13 04:27 PM
03/01/13 04:27 PM
PA.
"Little"John
"Little"John
PA.
I was going to say when I saw that it sure looked like a B1 valve cover gasket. Do you offer B1 intake manifold gaskets and if not are they in your future plans.
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
