Re: Removing/Installing Dashpad in a B-body
[Re: bonefish]
#1395145
02/28/13 07:32 PM
02/28/13 07:32 PM
Posts: 7,547 Albany, NY
67SATisfaction
The member whose name is actually Art
Albany, NY
I loosened the steering column, pulled the front seats, glovebox liner and the instrument cluster. Then it wasn't hard to worme my hands up underneath there and get all the 5/16" speed nuts off. Easier than dropping the whole dash assembly.
65 Satellite hardtop 361/4bbl console 727 2.76 67 Satellite convert 383/2bbl column 727 3.23 67 Lancia Fulvia Sport 1.3 Zagato. Alloy body, 1.3L V4 DOHC 4-spd 67 Lancia Fulvia Rallye 1.3. Alloy panel, 1.3L V4 DOHC 4-spd 71 Alfa Romeo GT Junior 1300 Zagato, 1.3L 4cyl DOHC hemi 5-spd 82 Alfa Romeo GTV6 2.5L SOHC hemi V6 5-spd transaxle 75 Maserati Bora US spec 4.9L DOHC hemi V8 5-spd ZF 77 Maserati Khamsin Euro spec 4.9L DOHC hemi V8 5-spd ZF 07 Aston Martin DB9 6.0L DOHC V12 6spd transaxle
[Re: 66Plymouth]
#1395147
03/01/13 09:01 AM
03/01/13 09:01 AM
Posts: 7,274 s.w.fl
bonefish
s.w.fl
Sounding like a bigger job than I was expecting. At this moment I'm not skilled to perform things like lowering a streering shaft and pulling the instrument cluster. Although I will be pulling the seats to replace them with nicer pieces.
Thanks all for the help.
if i can do it you can do it.its not hard at all.
Post deleted by moparts
[Re: bonefish]
#1395148
03/01/13 03:32 PM
03/01/13 03:32 PM
#1395149
03/01/13 04:00 PM
03/01/13 04:00 PM
Posts: 4,872 connecticut
pnypwr
connecticut
its all nuts and bolts...lower the columns easy take off the 3 bolts loosen plate or unbolt at firewall...cluster just take out the screws remove speedo cable and unplug harness carefuly...easy peasy...itll be harder to get your hands up and get the socket on the speed nuts...imo
"Are you gonna bark all day lil doggy? Or are you gonna bite?"
05 ram 2500 ctd 74 gremlin x 360 65 mustang 347 70 coronet R/T 440 03 Mach 1
