Gen 3 Hemi Build #1394731
02/28/13 12:52 PM
02/28/13 12:52 PM
Norfolk, NE
Racer33 Offline OP
Racer33  Offline OP
Norfolk, NE
After buying a couple junk yard 5.7 core motors i think i'm ready to start building my gen 3 hemi. My question is should i use my pre 09 heads or upgrade to the eagle head, I found new castings that can be delivered to my door for $750 for the pair. Plan is for a manley 392 kit with about 10.5 or 11 compression. drag pak intake and cam in the 230 to 240 duration range. So would the eagle heads be worth it compared to 1600 port and rebuild job on my existing heads?
Re: Gen 3 Hemi Build [Re: Racer33] #1394732
02/28/13 12:57 PM
02/28/13 12:57 PM
Charleston
sixpackgut Offline
Drag Week Mod Champion
sixpackgut  Offline
Charleston
the eagle head flows over 300 stock and will match up better to the drag pack intake.
I just got a intake from Muscle Mike and it is awesome
Re: Gen 3 Hemi Build [Re: sixpackgut] #1394733
02/28/13 01:05 PM
02/28/13 01:05 PM
Norfolk, NE
Racer33 Offline OP
Racer33  Offline OP
Norfolk, NE
Glad you checked in sixpack. Moparnut426 said i should talk to you. Thats the intake i was thinking of accept i was thinking the shorter version. The head i was thinking of on from a 2010 ram 1500. Would that be the eagle head? The price for 2011 and new is about $100 per head higher. Any recommendation on where to get a cam? The only ones i have seen with more then about 220 duration are from hughes.
Re: Gen 3 Hemi Build [Re: Racer33] #1394734
02/28/13 01:13 PM
02/28/13 01:13 PM
Charleston
sixpackgut Offline
sixpackgut  Offline
Charleston
Um, that is the short version
https://board.moparts.org/ubbthreads/show...&PHPSESSID=
the Eagle heads are the 2009 a newer 5.7 heads I believe. There are a ton of threads on here, I suggest you start reading all of them
Re: Gen 3 Hemi Build [Re: sixpackgut] #1394735
02/28/13 01:15 PM
02/28/13 01:15 PM
Charleston
sixpackgut Offline
sixpackgut  Offline
Charleston
Re: Gen 3 Hemi Build [Re: sixpackgut] #1394736
03/04/13 12:29 PM
03/04/13 12:29 PM
Ray, Racer33 has dug through every single inch of gen3 HEMI info. Why is there such a limit on cam choices, Seems only Hughes really offers a good selection. Honestly I havent really dug through the cam choices, but Ive done a little, and looked through comp, Hughes, and kinda fizzled out from there
How well do the stock lifters hold up to any performance upgrades? Is that an area of possible issues?
Re: Gen 3 Hemi Build #1394737
03/04/13 02:30 PM
03/04/13 02:30 PM
Charleston
sixpackgut Offline
sixpackgut  Offline
Charleston
from what I understand, stock lifters are excellent. The cam choice problems could simply be that the arena for cams is similar to what the LS guys have. Ever hear someone say they run a TRex cam, ya well, I don't know what the hell that means either.
Arrington, HHP, BES and there are a few others that specialize in modern hemi stuff and they support the LX forums and they probably do more homework on the new hemi's than Comp does. This is not to say you can't call up Porter and ask him to spec a cam from Comp for a new hemi
Re: Gen 3 Hemi Build [Re: sixpackgut] #1394738
03/04/13 03:11 PM
03/04/13 03:11 PM
Houston, Tx
AlexP Offline
AlexP  Offline
Houston, Tx
They run the stock 6.1 lifters in the drag pack cars out to 8000+ with no issues at all. They're a very good lifter.
If you treat a hemi like an LS2/LS3, you will be way ahead of the game. Once you decide what piston you want, decide your cam from there.
So long as you stay away from lobes like the XE-R, you'll be fine.
My Build thread: Let the hemi swap begin!
1968 wanna be pro touring whatchamacallit with some fancy stuff and a new roof skin.
Re: Gen 3 Hemi Build [Re: AlexP] #1394739
03/04/13 03:50 PM
03/04/13 03:50 PM
XE R?
Not familiar with that, sorry to be ignorant, but I havent a clue on that one.
Re: Gen 3 Hemi Build #1394740
03/04/13 04:16 PM
03/04/13 04:16 PM
Charleston
sixpackgut Offline
sixpackgut  Offline
Charleston
XE R?
its almost T REX backwards. exactly what I mean
Re: Gen 3 Hemi Build #1394741
03/04/13 08:18 PM
03/04/13 08:18 PM
Melbourne.....Oz-land
Moparmal Offline
Moparmal  Offline
Inertia Racing sell Crower grinds under there own branding....most are off the shelf fairly mild profiles...but they may have access to more race oriented stuff from Crower.
67 RO23 clone with 6.1 SRT Hemi and dual quads. Soon to have Drag Pak induction and Throttle body.
Re: Gen 3 Hemi Build [Re: Moparmal] #1394742
03/04/13 08:26 PM
03/04/13 08:26 PM
Houston, Tx
AlexP Offline
AlexP  Offline
Houston, Tx
I know it gets into names and wording that doesn't apply to the older mopar stuff. You'll see plenty of cams with the name being really prominent and the specs being treated as a minor detail. It's part secrecy and part marketing. You're not going to get cam cards for a lot of the really good custom grinds, nor will they even mention what lobe they're running.
People are still treating these motors as voodoo. They're not.
Are there any direct questions that I can answer for you?
Re: Gen 3 Hemi Build [Re: AlexP] #1394743
03/04/13 09:13 PM
03/04/13 09:13 PM
Moparmal Offline
Moparmal  Offline
Here,s one..
Have you ever measured piston to valve for the SRT Max in a 6.1?
I know what my Max Plus on a 110 LSA came in at...and its damn tight..
....just wondering what the normal SRT MAX 112 LSA P-V measures up as?
Re: Gen 3 Hemi Build [Re: Moparmal] #1394744
03/04/13 10:15 PM
03/04/13 10:15 PM
MN
hemidup Offline
hemidup  Offline
MN
Here,s one..
How tight? Also heard some G3 engine builder's use as tight as .027" quench.
Jerry Williams.
Re: Gen 3 Hemi Build [Re: Moparmal] #1394745
03/04/13 11:30 PM
03/04/13 11:30 PM
Houston, Tx
AlexP Offline
AlexP  Offline
Houston, Tx
Here,s one..
I've not measured that cam, but I have measured a 219/223 in a 5.7/6.1 and a 223/227 in a 6.1.
Both had at least .040 PTV.
Re: Gen 3 Hemi Build [Re: AlexP] #1394746
03/05/13 05:13 AM
03/05/13 05:13 AM
Moparmal Offline
Moparmal  Offline
Mine is .068th on the intake side...110th on the exhaust...218/227 566/556 110 lsa
Ive been told that is reasonable as long as I run good valve springs.
Just curios what the std SRT MAX on a 112 comes in at......
Re: Gen 3 Hemi Build [Re: AlexP] #1394747
03/05/13 11:58 AM
03/05/13 11:58 AM
Norfolk, NE
Racer33 Offline OP
Racer33  Offline OP
Norfolk, NE
My block is waiting in line at the machine shop now. It came from an 06 pickup. Are the plastic pugs in the valley available as replacement parts? If i have the block baked they will surely be gone. Should i just leave them and have it steamed?
Re: Gen 3 Hemi Build [Re: Racer33] #1394748
03/05/13 12:22 PM
03/05/13 12:22 PM
Guitar Jones Offline
You should be able to remove them.
Re: Gen 3 Hemi Build [Re: Guitar Jones] #1394749
03/05/13 12:36 PM
03/05/13 12:36 PM
Norfolk, NE
Racer33 Offline OP
Racer33  Offline OP
Norfolk, NE
I removed the bolts from the retainers and it doesn't seem like the retainers will come off without the plastic plug coming out and i'm pretty sure i cann't get the plug out with breaking it. Are they epoxied in?
Re: Gen 3 Hemi Build [Re: Racer33] #1394750
03/05/13 12:38 PM
03/05/13 12:38 PM
No, just an o ring IIRC.
