92 Cummins No OD/Cruise
#1394454
02/27/13 06:16 PM
02/27/13 06:16 PM
Posts: 1,305 Lakewood, Colorado
herkamer
Lakewood, Colorado
Trying to help my dad out. 92 Cummins 4x4 suddenly lost OD and cruise. Speedo still works, so doubtful it's the VSS. Does anyone have a chart for troubleshooting? I am leaning toward the PCM died, but there are no codes in it.
Matt 69 Dart Swinger 340 83 W350, Megasquirted with 46RH Old news: 72 Demon street/race mobile Latest: 70 Duster backhalf car and even more
Re: 92 Cummins No OD/Cruise
[Re: herkamer]
#1394455
02/27/13 06:26 PM
02/27/13 06:26 PM
Posts: 28,067 Irving, TX
feets
Senior Management
Senior Management
Irving, TX
OD is usually the TPS. I went through a few on my 92. The CTD is really hard on them. Growing tired of $300 sensors, I put a pressure switch on the OD and run it that way. I wish I knew the answer on the cruise. Mine is dead too. I think it's the clock spring. http://www.dieseltruckresource.com/dev/1st-gen-ram-all-topics-f93.html
[Re: feets]
#1394456
02/27/13 07:53 PM
02/27/13 07:53 PM
herkamer
Lakewood, Colorado
TPS is good, I get a nice smooth range of ohms with no flat spots as the pedal is depressed. I will double check the voltage, but it was set about 3 months ago when I was fixing his A/C.
[Re: jimbob101]
#1394459
02/28/13 01:08 AM
02/28/13 01:08 AM
herkamer
Lakewood, Colorado
I have also read the coolant temp sender on the block behind the pump can cause issues. I'll double check all the connections; it is possible that something could be corroded thanks to the ice slicer garbage they put on the road.
Chris, how did you determine that the computer puked?
[Re: chrisf]
#1394462
03/08/13 11:03 AM
03/08/13 11:03 AM
A 92 dosnt have too many electronics in the tranny, but the tranny temp switch on the cooler line could be reading faulty thinking the thing is under 20 degrees or so, whatever temp is the temp to keep the OD from coming on. I had a 91.5 and it would intermittently work, but was way worse in the cole, I had a part truck laying around, swapped that, and it repaired the issue.
As for the Cruise, how is your brake switch?
#1394463
03/08/13 11:19 AM
03/08/13 11:19 AM
herkamer
Lakewood, Colorado
Brake switch is ok. It has been intermittently working. Sometimes it will go into OD and at the same time cruise will work. When it quits, they both fail. Appparently the volt meter is showing under 10v charging, then it will bounce up to where it's supposed to be. Have to get a meter on it to see what the real charging story is. I'm having pops clean the connector and computer pins to see if there is some junk that's causing the intermittent issues. Leaning pretty hard toward a dying computer. He wants to take it to the dealer for diagnosis, but that is 3/4 of the cost of a computer.
[Re: herkamer]
#1394464
03/08/13 12:33 PM
03/08/13 12:33 PM
If they are closely related, you may be having a wireing chaffed, IIRC they share some of the same wires for power and ground, I dont have a wireing schematic handy, but maybee trace the wires back and see what you find. My 91.5 was mouse ridden before I got it, I had a lot of little stupid issues and 99% off them were wires chewed on. I will see if I can find ya a schematic and copy it on here.
#1394465
03/08/13 12:43 PM
03/08/13 12:43 PM
I cant copy and paste the schematic I have becuase its on mitchell on demand and you dont have my sign in, or passward, so you will just get a blank page. BUT I did see the cruise and the tranny thermal switch shafe a what looks like a sence return wire from the SBEC, so its could be the SBEC or the thermal switch. I know Id be trying a temp switch.
#1394466
03/08/13 01:00 PM
03/08/13 01:00 PM
herkamer
Lakewood, Colorado
I have a Chilton wiring diagram. Very generic, but it has color codes and most of those should be the same gas vs diesel on cruise and OD. I don't know if the gassers use a tranny temp switch, but will take a look at it tonight.
[Re: herkamer]
#1394467
03/16/13 12:55 AM
03/16/13 12:55 AM
herkamer
Lakewood, Colorado
Latest update: A/C also doesn't work when everything else is down.
New computer = nothing fixed
Grounds checked, still nothing. Any other ideas?
[Re: chrisf]
#1394469
03/16/13 09:24 AM
03/16/13 09:24 AM
Posts: 6,653 Near Reading PA USA
pinkduster
Near Reading PA USA
One time, on my 92, the AC stopped working and when I went to put the windows down, they didn't work either. I don't know about the cruise control and overdrive because I only drove it to a shop less than a mile up the road to be fixed. Turned out to be the ignition switch. I have no idea if this could be your problem, I'm just throwing it out there because of the AC issue you mentioned.
[Re: jimbob101]
#1394472
03/18/13 01:17 AM
03/18/13 01:17 AM
herkamer
Lakewood, Colorado
The common tie to every single thing that works or not is the computer. It wasn't terribly expensive. I hate throwing parts at a problem though... I didn't make that decision, so have to pick up and regroup. We haven't done anything with the temp sensors. TPS has been set and also checks out for smooth operation. With the manuals on the way, I think we should be able to ferret out the offending issue.
[Re: herkamer]
#1394473
03/18/13 09:03 AM
03/18/13 09:03 AM
Posts: 522 Lenox Iowa
MMiller
Lenox Iowa
I would check the plug for the speed sensor on the front of the engine. If it is unplugged, or poor connection, the charging system, and the a/c won't work. I imagine the od and cruise won't work either because the trucks ECM doesn't know the engine is running without input from the speed sensor on the front of the engine. If the ECM doesn't know the engine is running, then many things won't work.
The speed sensor reads off notches in the dampner, and the plug in the harness is right next to the thermostat on the front of the engine. I fought my a/c and no charging for better part of a week before I had found the harness unplugged to the speed sensor. My truck is a 5 speed, so I had no problems with trans shifting.
Michael
93 W250 CTD getrag, Bosch 185 injectors, AFE air filter. Trailer puller, daily driver, 90 W250 CTD 727 with smokin 5" stacks. Off road truck
75 Dodge W200 440 4spd 4x4 locked front and rear, twin disc clutch, E85. Pulling truck
