Re: home ported heads
[Re: poboyengineering]
#1394271
02/28/13 08:12 PM
02/28/13 08:12 PM
Posts: 394 Ohio
moparjoe360.4
Ohio
the swirl port thing sort of worries me..it looks like they take up a lot of room, and the serious heads dont have them.
Are you talking about the rotator on the exaust valve? If you are it will cause problems even with a small performance cam.... I have a head with a hole in it to prove it. One of my valves broke at the retainer (from coil bind?)fell down in the cyl. bent the rod n punched a stem sized hole in the head. ![](/ubbthreads/images/graemlins/whistling.gif)
#1394277
03/01/13 05:22 PM
03/01/13 05:22 PM
Posts: 685 pennsylvania
poboyengineering
pennsylvania
ive had some conversations with john cadamore (thanks john!) and the subject of putting a 2.05 intake into the 308 heads came up. anyone done this? what were the results?
It may be ugly, but it sure is slow.
Girls comb their hair in rear view mirrors and the boys try to look so hard....
