Tranny problem, 2000 Ram 4X4 hanging up in 1st & 2nd #139369
10/20/08 09:29 PM
10/20/08 09:29 PM
Thunder Bay,ON
LilRedDave Offline OP
Thunder Bay,ON
Any ideas on what we're in for. Buddy of mine is have a problem with is Ram, it's hanging up in 1st & 2nd until you let of the gas. it's in a 2000 1/2 Ram 4X4 wih a 318. Would this tranny be a A518 also? Any help or ideas are much appreciated.
Re: Tranny problem, 2000 Ram 4X4 hanging up in 1st & 2nd [Re: LilRedDave] #139370
10/20/08 09:50 PM
10/20/08 09:50 PM
Kissimmee Fl.
dusturbd340W5 Offline
Kissimmee Fl.
yes 518 could be a pressure cable problem or a problem with a tps or governor pressure solinoid just have to have it check out
70 duster full chassis super pro 416 CNC Indybrock heads 727 w/brake
best so far 1.212 60 6.219 in 1/8 at 110.88 9.768 at 137.81 1/4
Re: Tranny problem, 2000 Ram 4X4 hanging up in 1st & 2nd [Re: LilRedDave] #139371
10/21/08 09:20 AM
10/21/08 09:20 AM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
Check the kickdown band adjustment. It's external to the trans so it would be one of the easier things to inspect. The prob you describe definately can be caused by a loose band.
Re: Tranny problem, 2000 Ram 4X4 hanging up in 1st & 2nd [Re: J_BODY] #139372
10/21/08 05:22 PM
10/21/08 05:22 PM
Thunder Bay,ON
Thunder Bay,ON
AnNyone have a tightening spec on that one, and thanks for the suggestions.
Re: Tranny problem, 2000 Ram 4X4 hanging up in 1st & 2nd [Re: LilRedDave] #139373
10/21/08 08:19 PM
10/21/08 08:19 PM
chatham, Ilinois
fox Offline
super street
fox  Offline
super street
chatham, Ilinois
Actually it is a 46re.
Check for codes. It could be speed sensor.
Re: Tranny problem, 2000 Ram 4X4 hanging up in 1st & 2nd [Re: LilRedDave] #139374
10/21/08 09:10 PM
10/21/08 09:10 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
Change the fluid and filter - use only Mopar ATF+4 , see if it helps
sounds like the seals are getting weak
Re: Tranny problem, 2000 Ram 4X4 hanging up in 1st & 2nd [Re: gtx6970] #139375
10/22/08 12:51 AM
10/22/08 12:51 AM
Chicago Burbs
sthemi Offline
sthemi  Offline
Chicago Burbs
Had the same problem with my 2001 Ram, it was the solenoids. $300 to fix at a trans shop.
