magnum disc brakes #1393657
02/26/13 01:32 AM
02/26/13 01:32 AM
connecticut
pnypwr Offline OP
pnypwr  Offline OP
connecticut
I saved a set of disc off a magnum...im trying to part with some stuff..will these work without issue on a 68-70 b or 70-4 e body? or should I chuck them as I most likely will never own a late b body
"Are you gonna bark all day lil doggy? Or are you gonna bite?"
05 ram 2500 ctd
74 gremlin x 360
65 mustang 347
70 coronet R/T 440
03 Mach 1
Re: magnum disc brakes [Re: pnypwr] #1393658
02/26/13 01:49 AM
02/26/13 01:49 AM
Phoenix - surface of the sun
nomore65BelvJim Offline
F,M,J and late B stuff is good for drum upgrades on A and earlier B bodies. Are they the larger discs? Complete set-up?
Re: magnum disc brakes [Re: nomore65BelvJim] #1393659
02/26/13 02:29 AM
02/26/13 02:29 AM
connecticut
pnypwr Offline OP
pnypwr  Offline OP
connecticut
all there I didnt measure the dia of the rotors...ill shelf them just in case...
05 ram 2500 ctd
74 gremlin x 360
65 mustang 347
70 coronet R/T 440
03 Mach 1
