Re: Fuel sending units
[Re: Beep Beep]
#139318
10/20/08 08:33 PM
10/20/08 08:33 PM
RapidRobert
alot of folks here have posted recently about various(aftermarket) ones not being accurate so gets some good info before you purchase.
[Re: Beep Beep]
#139320
10/21/08 12:34 AM
10/21/08 12:34 AM
Posts: 216 united kingdom
Simonic
united kingdom
i got one from year one(1/2)to replace my 5/16 unit. never reads above 1/2 full. old unit worked just fine
Keeping the Bee Buzzin'
[Re: Simonic]
#139321
10/21/08 12:53 AM
10/21/08 12:53 AM
Posts: 6,098 Valencia, España
NachoRT74
Valencia, España
I would go with VANS AUTO SALVAGE on ebay ( I got mine from them on less than $50 including shipping, about one year ago )... they are actually on $50-70 rate for SAME UNITS than some others offer in $100-120 rate( at least those what I saw at Carlisle ). plus:
-they are BRASS floaters.
-rheostat to stud link is a METALLICK STRIP like the original, not a wire like those called "mopar" units
Only cons I found is the outlet is straight and original is angled... that makes a tight fitment with hose because there is not enough room around, and also an allmost exact lenght with ground strip
[Re: toolmanmike]
#139326
10/23/08 07:14 PM
10/23/08 07:14 PM
Posts: 1,320 Lees Summit, MO
BrianT
Lees Summit, MO
I bought this one off of Ebay back in August and it has been a nightmare. Should have known it was trouble from the sellers name. link to cheap ebay sender The gasket leaked when we reassembled it. Since then, we have tried several different gasket combos and even o-rings. We even ran two gaskets, one on each side of the sender) and a new lock ring. No luck. It will stop for a while, but any time there is a change in temp, it starts dripping gas in my garage. Put the original sender back in and no leak! The metal is thinner than the original. I am ready to scrap it and buy the one from Quantum and see if it's any better.
1970 Duster 340 clone
