Re: 99 Dodge Ram 1500 4x4 crank sensor....
[Re: Chad Bittle]
#1393102
02/26/13 03:47 PM
02/26/13 03:47 PM
Posts: 21,345 Marysville, O-H-I-O
70Cuda383
Marysville, O-H-I-O
After all the rain we had is when it quit running, threw a p0138 code so I've since then changed both o2 sensors, cap, rotor, coil, cam sensor and crank sensor, still nothing.
The 138 is an O2 sensor code, but you already tried those.
Is the ASD relay working? Does the fuel pump prime for a few seconds then shut off?
Any other symptoms? Clear the codes and try again, let us know what codes you get.
**Photobucket sucks**
[Re: 70Cuda383]
#1393103
03/03/13 10:07 PM
03/03/13 10:07 PM
Posts: 687 Ohio
Chad Bittle
Ohio
Welp, after all that I touched the positive and negative cables together to reset the computer (which I didn't know, I thought having the negative unhooked for longer then 15 minutes did the same thing) and it started right up. Ran like crap for a few minutes, now good as new. I feel ashamed lol ![](/ubbthreads/images/graemlins/frown.gif)
