I have installed US Car Tool frame connectors on a 71 barracuda vert. I installed connectors closer to the torsion bar socket so as to not obscure the fuel line holes. Now the cable connector that connects the front to rear cable will interfere with the drivers frame connector when the brake is applied. Any thoughts on solution? Change from the 71 to 72-74 style cable connector as shown here
http://www.billrolikenterprises.com/products.asp?cat=13&pg=2 ? Somehow move the front cable anchor point closer to the frame connector to increase clearance? Cut a window into the connector to provide clearance?
How are folks dealing with the adjuster side? Topcat seems to have kept the original adjuster and let it pass thru the connector to the original anchor point while Bill Alphin changed to an 8" long GM 5/16" battery j-bolt and anchored it to the passengers side frame connector.
