Re: Lower control arm clunk from pivot point, fixable?
[Re: conv440]
#1392954
02/26/13 02:34 PM
02/26/13 02:34 PM
Posts: 27,485 So Cal
autoxcuda
So Cal
I was going to heat the metal and give a few whacks to the rear outer shell to try to close the tolerance between the torsion bar mount and the rest of the arm. Same place you are experiencing some slop in your earlier post (looseness/gap/wear).
Oh ok. That could use heat.
